02 Avalanche (ABS)
userpete1037
12-25-2009, 06:16 PM
For some reason the there is a constant buzzing from the Electro-Hydraulic Control Unit (EHCU). My OBD II Scanner pulled two codes: C0265 EBCM relay circuit - open and C0267 Pump motor circuit - open or shorted circuit. Could the EHCU be faulty?
MT-2500
12-26-2009, 07:46 AM
You need to get and go threw the repair flow charts for you codes.
A good factory repair manual or.
http://www.alldata.com/products/diy/index.html
And remember always clear codes and see whatcomes back.
dorman68
12-28-2009, 01:58 PM
Common problem. My coworker needed an abs module because the built in internal relay was stuck and the pump continued to run.
danielsatur
12-28-2009, 02:02 PM
Don't forget to check fuse's & relays!
A blown fuse = open circuit
userpete1037
12-28-2009, 09:59 PM
Thanks for all the responses. I'll let you know what happens.
