89 dakota no start
dakjay
12-22-2009, 01:50 PM
i have a 89 dakota with 3.9l motor that will not start new coil new pickup in distributor gets feul no voltage at coil please help?
jpb53
12-23-2009, 11:15 AM
The wire that feeds power to the coil should be gray with a black tracer. That wire goes back to a splice and that wire color is dark green with a black tracer. That wire (dark green with a black tracer) also supplies power to the injectors; oxygen sensor heater and the fuel pump. Power for that circuit come out of the ASD relay which is mounted on the left fender. The relay is powered up for a couple seconds at key on the then is deenergized. The relay is the powered up when the computer sees a signal from the distributor pick-up coil. Red wire at ASD relay is power in and supplied by a fusible link. Dark green with black tracer has been explained. Dark blue with a white tracer is power supplied by the computer. Dark blue with a yellow tracer goes to the computer and is grounded by the computer to turn the relay on.
