I have a STRANGE problem, don't know where to place it...
HerculesMO
12-07-2009, 09:26 AM
(2004 Mazda3s Hatchback)
I turn on my car, doesn't sound weird at all.
If I stop DEAD, and accelerate and make a RIGHT turn, the car 'chugs' and make weird noises. As soon as I straighten the wheel out, it goes away. If I make a left turn, it doesn't happen. I thought it might be something stuck in the wheel well, but it's not. I'm kind of out of ideas but I appreciate any help you guys may be able to give. It's not a suspension thing, it's definitely from the engine bay. It makes noise when I'm in gear, not while in neutral or park.
Thanks, really need some help here!
jdmccright
12-07-2009, 10:07 AM
Not familiar with your car, but I would look at problems with either the power steering pump or the steering rack. A blocked or stuck internal valve can cause the pump to bog down the engine. It's not much help but I hope it starts you in the right direction. Good luck!
MagicRat
12-07-2009, 10:15 AM
It just might also be a bad outer CV joint
HerculesMO
12-07-2009, 11:46 AM
It happens when I'm standing still too -- not just moving, FYI.
MagicRat
12-07-2009, 12:25 PM
okay, that was not clear from the first post. In that case, it's power steering-related, as noted above.
RahX
12-15-2009, 12:07 AM
Doesn't the 3 have an electric power steering pump?
