2000 seat heater
Volsav
11-25-2009, 11:07 PM
2000 Blazer LT 4wd 4dr
Driver's seat heater not functional. Power going to switch. Are parts available? Is a replacement seat available?
If yes to any of the above, any ideas about where to look would be appreciated.
MT-2500
11-27-2009, 11:52 AM
It takes more than power to switch to work it.
Always check for 12 violts on both sides of all fuses and grounds.
Check for 12 volts to orange wire to seat module.
If 12 volts hook test light between orange and black wire.
If test light lights there with ket on hit high switch and check for pink wire to seat/module for 12 volts.
Are you getting 12 volts on pink wire to seat?
Post back what you find there.
MT-2500
11-29-2009, 09:50 AM
For anyone to help please give us some feedback
And to say thanks to anyone that has helped .
Also posting back how it went helps others that may have the same problem.
Let us know how it is going.
Thanks
Volsav
12-06-2009, 11:04 AM
All tests show power going to seat module.
MT-2500
12-06-2009, 11:23 AM
Is the seat heater also getting power switch on?
Volsav
12-06-2009, 12:13 PM
yes
laxman21
12-06-2009, 08:21 PM
Anything unplugged under the seat?
Volsav
12-07-2009, 12:26 PM
Thanks for your thoughtful comments.
No, nothing unplugged. The heating elements woven into the leather upholstery are not functional. I am looking for ideas as to how to replace them.
laxman21
12-07-2009, 09:09 PM
I don't know if you know but, there are several plugs that link the seat heaters, some small orange ones that form the circuit. The seats have 3 pads and the seat back 2. Now, I don't know if one of those comes unplugged if it would cause the whole system to stop working or if a break in one would do the same. Or it could be a simple as a broken wire. Just a thought.
Junk yard seats, would be the cheapest to replace them.
rmwilson
12-16-2009, 09:59 PM
I have the same year truck... and just as an FYI ... my drivers side seat heater, does not always work, its intermittent ... I have found it always works the second time I start the truck, so if I start it drive stop get gas when I restart it the seat heater works?
Any idea why this might only work every second start.
