1998 S10 major electrical problem
natedoggie
11-20-2009, 11:50 PM
s10 2.2 5 spd 2wd... I was sitting at the light and my truck died... wouldn't start. I had no power to gauges or headlights, flashers and stereo worked. the daytime running lights didnt work, so i tried to turn the headlights on with the switch, there was a loud buzz from fuse box under the hood. when i turn on ignition there is no power to anything, but stereo. doesnt crank over, speedo shows 100 mph. no dash lights, no power to fuel pump... no gauges read anything except voltmeter reads 12v. i have power from the ignition switch. Sorry for the choppy post... Im a bit irritated with this truck.
I was thinking it was ignition switch or bad ground somewhere... Help please!
MT-2500
11-21-2009, 08:41 AM
Start at the battery and battery cabels.
Both neg and positive and always check grounds to.
If good 12 volts on battery and cabels go to fuse boxs and check for full power to them and check fuses for 12 volts both sides.
natedoggie
11-21-2009, 06:19 PM
fuse box has power,none of the fuses are blown, batt cables are good... I will try checking the fusable links... I am out of ideas...
danielsatur
11-21-2009, 06:31 PM
The demand for power is a great demand today, because of the electric fuel pump, ECU, PCU, Control modules, and digital dash.
How old is this battery?
natedoggie
11-21-2009, 06:37 PM
about a year old... took it to autozone they did a load test everything was good...
natedoggie
11-21-2009, 06:38 PM
battery is about 1 year old, took it to autozone they did a load test.. it passed..
MT-2500
11-21-2009, 06:47 PM
Check all fuse for 12 volts both sides.
Check headlamp switch fuse no 1 a 10amp
Check mega 115 fuse
