02 window problem
tempfixit
11-03-2009, 12:20 PM
02 Lesabre custom, 110k
The drivers window goes down when you turn ignition switch on. Have to monkey with the switch to get back up.
I haven't looked at it yet but I am thinking a faulty master window switch.
Is this a common problem on these vehicles?? (Friends Car)
thanks for any input
claimed4all
11-03-2009, 12:32 PM
In the window department the most common problem is the motor/cable system. Bad switches are no more common than any other car. I had this happen to a similar car and I was able to switch the driver and passenger leads at the switch so the drives window worked well unit I purchased a replacement.
tempfixit
11-03-2009, 12:35 PM
thanks claimed4all (http://www.automotiveforums.com/vbulletin/member.php?u=573661), I'll have to take apart and look at the switch.
