Runs Rough, No Error codes
Technocrat
10-30-2009, 02:49 PM
I have a 98 Safari 4.4 Vortec with 225,000 miles on it.
It is running rough with no error codes. It is hitting on all 6 cylinders.
It has a new distributor, cap & rotor.
Bosch Platinum plugs & plug wires are about a year old.
94&92Astro
10-31-2009, 12:26 PM
Make sure none of your plug wires are in contact or near contact with the exhaust manifold. Also a good idea to remove the doghouse and check out the engine while idleing at night to check for any errant spark. I stumbled upon a leaking wire this way which had come in contact with the manifold and was throwing an intermident spark into manifold. I wish I had started this way as I would have saved myself alot of time and money. Also alot easier to check vacumn hoses while doghouse is off.
Technocrat
11-02-2009, 02:39 PM
Thanks! :)
I had not thought of looking after dark. I unplugged the wires one at a time while running & got a pronounced miss on all six so whateever it is does not seem to be isolated to a single cylinder.
I have checked for vacuum leaks & not found any.:banghead:
MikeS144
12-16-2009, 06:59 AM
I have a 94 with the vortec and had a similar problem. Does your exhaust smell of fuel? If so then you should look and your injector. I am not sure if yours has the same injector as mine, but the spider injector as it is called which I have has a history of causing problems like that.
BTW, how did the plugs look when you changed/pulled them?
Technocrat
12-18-2009, 10:37 PM
Thanks fir the input.
No, I am not smelling gas. I have tried running Gumout High Millage fuel system cleaner through it in case the injector was clogged, but to no avail.
The plugs just had a light ash color showing good combustion.
old_master
12-18-2009, 10:56 PM
AC Delco 41-993 spark plugs will make a world of difference over the Bosch plugs. Usually they will set a DTC P0300, but not always. The only way you'd spot this problem is with an enhanced OBDII scan tool. Also, check fuel pressure and leakdown rate. Key ON, engine off, fuel pump running, fuel pressure must be 60psi to 66psi and must remain above 55psi for 3 to 5 minutes after the fuel pump shuts off. Insufficient fuel pressure can cause a random miss without setting a DTC.
Technocrat
01-24-2010, 01:53 PM
First, please allow me to apologize for my slow response.
Since my last post I have had a much larger problem to deal with on this vehicle.
In late November the van suffered a catastrophic water pump failure that destroyed the fan, shroud, & radiator as well. (pictures at the end of this post.)
Since this was a very expensive (at least on my budget) repair it has taken me a while to acquire the revenue to complete the repair.
During the"autopsy" of the water pump failure my son & I found that the fan clutch bearings had frozen, & the fan had been spinning on an eccentric. After reassembly the engine has run smoothly. Apparently this was the cause for the engine vibration & subsequent water pump failure. The pump casting showed signs of severe crystallization at the points where the fracture occurred.
Old Master, thanks for the advice on the plugs. I have taken half of it. After reading your post I checked my notes & determined that these plugs had about 90,000 miles on them. I went ahead & replaced them with new Bosch P4 Platinum plugs. I have been running P4s in all my vehicles for a number of years due to the increased gas mileage & plug longevity I have experienced.
Thanks to all of you for your support on this problem.
After my recent experience I would like to recommend that anyone with a GM clutch fan with over 200,000 miles that you keep a close eye on the clutch. Clutch failure is expensive, & at $60 to for a new clutch, replacement could be cheap insurance.
http://i570.photobucket.com/albums/ss148/Techno57/Pics/Van/SDC10125a.jpg
http://i570.photobucket.com/albums/ss148/Techno57/Pics/Van/SDC10141a.jpg
http://i570.photobucket.com/albums/ss148/Techno57/Pics/Van/SDC10140a.jpg
