PCV Grommet
orange57
10-24-2009, 02:41 PM
Does anyone have an easy way to get a new PCV grommet pressed into the hole in the the front valve cover? I've been battling with it for a while and having no luck.
thanks,
matt
RallyEclipse98
12-01-2009, 08:07 PM
Flat head screw driver?
orange57
12-06-2009, 11:28 AM
That didn't quite work. I just couldn't get it to slip into there. So i ended up slicing one of the larger portions off, so it had a cross section that looked somewhat like a T. I then put the adhered the grommet using RTV, and put a smooth bead around the outter edge as well. Thus far it seems to be working well.
RallyEclipse98
12-07-2009, 08:41 PM
Did you not have the proper gasket? I just put a new PCV valve in and I went out with the old and in with the new in less than 2 minutes.
