1985 VW diesel won't start?
fiddlinrick
10-22-2009, 12:44 PM
I have a 1985 golf diesel that won't start. I put new glow plugs in. and
a relay and still it won't start. Any suggestions to try?
Franco2112
10-22-2009, 01:20 PM
Changed out fuel filter?
fiddlinrick
10-22-2009, 01:32 PM
Yes the fuel filter was replaced as well as the glow plugs, and the glow plug relay. I
did a continuous start 3 times and felt the area around the glow plugs and it did not
warm up. Could it be the ignition switch?
Franco2112
10-22-2009, 04:22 PM
Yes, ignition switch could be the fault but first, any other electrical issues? When did the non starting issue start?
fiddlinrick
11-02-2009, 12:41 AM
I had a new switch put in about 4 months ago, but everything lights up on
the dash. the last time the glow plug light did not come on. Now is times its
self out. I pulled the first injecter line and nothing comes out. Is there a
pump in the fuel tank? The injector pump has only about 30,000 miles on it.
So I just don't know what to try next. Should I have someone turn the
motor over while I put fuel through the injector Pump. The injector pump
does not seem to be leaking fuel anywhere. I drove home. parked the car,
about 1 hour later started the car and moved it out of the driveway. went
out the next morning and it just wouldn't start. I have worked on it for
about 2 weeks now and can't get to the problem. thank you.
NYC4LYFE
12-03-2009, 07:43 AM
im not familar with diesel you might want to check VWvortex.com, might get some useful info in the MK2 & Diesel forums, goodluck. post updates if you have any
stevejones75
01-20-2010, 08:57 AM
tats a useful advise.. Thanks and I think diesel engine always create problem when the engine is cold....
danielsatur
01-20-2010, 09:05 AM
Need to check the compression on each cylinder, the fuel injectors can be cleaned at a diesel shop.
Keithuk
12-28-2010, 01:36 PM
Sorry this is an old thread but I would suggest to any TDI owner join a great TDI Forum (http://www.myturbodiesel.com/forum/) ;)
