2004 Montana Dash Lights Not Working
dgharley
10-18-2009, 12:23 AM
i have a 2004 montana, i have no dash lights, no raidio lights at all. in the daytime if i turn headlights on manually my raidio plays but the lights to raidio go off. and no raidio light. i have checked all fuses, all running lights, parking and turn lights, instrumentation brightness control knob. anybody else had or have this problem? i just tried a differen't headlight switch, didn't fix problem. please help. thanks in advance.
Noam Zane
10-18-2009, 04:02 PM
I'll assume you checked the instrumentation brightness control knob. First things first and all.
dgharley
10-19-2009, 06:36 PM
yes i checked the brightness control knob.
craig-o
11-03-2009, 01:45 PM
I have a similar problem on my 2003, but it's intermittent. The only solution that has worked for me so far is to disconnect the battery for a few minutes, then re-connect. That seemed to solve my problem for a couple of months, but it's back again.
When the headlights come on (they're automatic), sometimes the dash lights go dark - all the dash lights, and the radio is black, but everything functions normally. If I put the car in park, set the parking brake, shut the car off and re-start, they usually come back on. It's obviously not a blown fuse or the dimmer switch if re-starting it sometimes fixes the problem.
Anyone got any guesses?
craig-o
10-18-2011, 02:19 PM
Thought I would follow up with the final solution to this problem. I replaced the headlight/dimmer switch about 6 months ago and the problem has not recurred.
