240hp uh?
all power
10-08-2009, 01:56 PM
took my car to a dyno before i put mods on it i was only pushin 200hp to the wheels? Now you are telling me im loseing 40hp threw the trans and axles? that sounds like bulls*&# to me and after i modded it im back up to 240hp to the wheels... if i spent close to 700$ just for 40hp than these cars suck!!! i figured i would be around 300hp in the engine and 280hp to the wheels .....PLEASE TELL ME IF SOMETHING WRONG... i love the car but not if its going to run me a arm and a leg. 2000 GTP
all power
10-08-2009, 02:10 PM
sorry i forgot to list my mods HEADERS/HI-FLO CAT/C.A.I/SUPER44s/3.25 PULLEY/PCM/PLUGS/WIRES/COSTOM PIPES/180 T-STAT/AND IM RUNNIN HALF 110OCT/93OCTANE
grandprixgtx00
10-08-2009, 02:59 PM
dude, its a FWD car...yes you lose HP and alot of it on a FWD car. If you want a muscle car then go out and buy one. when your finished...I'll race you with my GTX and we'll see what happens
all power
10-08-2009, 03:25 PM
i understand losing some HP but 40hp? i could understand if it was a rear wheel drive car but its not!!!! it still doesnt sound right. like i said loseing 10 or 15hp i understand but 40? and after the mods i did i should be around 300hp in the engine and about 280 to the wheels and if you spend 700$ on mods to your car i better be getting more than 40hp:shakehead:shakehead:shakehead:shakehead
grandprixgtx00
10-08-2009, 03:32 PM
you actually lose more power to the wheels in a FWD car than a RWD car. a bone stock grand prix GT dynos at around 165-170 HP. according to GM the 3800 at the crank is 210...you do the math.
like i said...if you want a Powerhouse then get a muscle car. you can make a GP fast, just takes time and money (so do all other cars) most of us here mod our GP's because we love them...not because we figure they're going to make insane amounts of HP. though i have rode in a twin turbo GP that dynod at 535HP on 93 Octane :eek:
all power
10-08-2009, 03:44 PM
well this might sound crazy to you but thats why i bought a GTP not for the hp. but i have owned GPs ever since i was 18. but never had a GTP, with all the hype about them and what you can do to them and not so much motor wise but everything else and the motor is just iceing on the cake.and like i said i still think something is wrong with those #s on the dyno? i should be around 280hp to the wheels .... i have read up on the mods and unless there lying about what type of hp you gain the #s dont add up:banghead::banghead:
VR43000GT
10-08-2009, 05:19 PM
If you want 280 at the wheels you will need approx 310-320 bhp which is not going to happen with your modifications.
From your mods list:
"HEADERS/HI-FLO CAT/C.A.I/SUPER44s/3.25 PULLEY/PCM/PLUGS/WIRES/COSTOM PIPES/180 T-STAT/AND IM RUNNIN HALF 110OCT/93OCTANE"
Headers, HF cat, and intake I would guess net you about 20-30 hp tops. Not sure what custom pipes are? Exhaust? Your running around 11 psi from what I have seen with your pulley size. I am not sure of the efficiency range of your stock Eaton M90 (IIRC) blower but I am sure that is good for a couple extra ponies. The rest of your mods are just supporting mods it appears. And I am not sure why you are running a blend of 110/93 octane. Do you guys really need to run 100+ octane on only 11psi?! My guess is that was just a waste of money but I am sure Bob or Rich or Blake will be able to confirm or deny. You have to take into account some cars respond better to mods than others as well. Frankly $700 doesn't seem all that expensive for 40whp on your motor but that is just me.
EDIT: By the way, front-wheel-drive cars do not lose more power in the drivetrain than RWD vehicles. Maybe in some rare circumstances a few RWD cars could net the same drivetrain loss as a FWD car in such cases as a Corvette possibly as it has a transaxle just like a FWD car. However, FWD cars will not lose MORE power than a RWD car to the wheels.
BNaylor
10-08-2009, 08:41 PM
The only advice I can give is screw the dyno test results. It doesn't mean anything. How does it do at the strip (preferable) or street if you desire meaning the realworld? The SC mods produce more torque than horsepower. The headers shift the powerband to mid-hi range.
HotZ28
10-08-2009, 11:14 PM
Factory ratings on your car were advertised as "SAE NET HP" (measured at the engine's crankshaft). You can take the "wheel HP" & add 10% (as conservative figure for a FWD), to determine engine SAE NET HP. So let's say you have 240-hp to the wheels + 24 = 264 SAE net HP. (Not bad for 700-bucks) BTW, torque is what moves the vehicle, not HP! Power available at the road is generally 10% to 20% less than the engine's bhp rating due to coastdown losses, most of which are due to the vehicle's rubber tires rather than true transmission losses. Front-wheel drive cars (provided a transverse engine layout is used) suffer slightly lower coast down losses due to the absence of the beveled crown and pinion gears used to change the drive direction in the back axle of a RWD car.
grandprixgtx00
10-09-2009, 01:04 AM
:iagree:
:iagree:
VR43000GT
10-09-2009, 01:57 AM
factory ratings on your car were advertised as "sae net hp" (measured at the engine's crankshaft). You can take the "wheel hp" & add 10% (as conservative figure for a fwd), to determine engine sae net hp. So let's say you have 240-hp to the wheels + 24 = 264 sae net hp. (not bad for 700-bucks) btw, torque is what moves the vehicle, not hp!
:1:
:1:
all power
10-09-2009, 03:56 PM
ok thats understandable so let me ask you list. if i was to rebuilt my motor and bore it 30.over and keep my mods / port the heads/ maybe mod the cam and lifters get a intercooler for the charger... would i be around 300bhp? remember this is a daily driver but i have the chance to get some more work done to it. and drive the buddies car round until spring. im just tired of getting beat by cars and i dont race all the time just when asked..hahaha
robkiehl21
10-15-2009, 05:07 PM
Few days later but I just wanted to say, that in an automatic car, you lose about 10% of the power going to the wheels through the torque convertor and to pressurize the hydraulics and such for the transmission to shift gears.. If it were manual you could probably expect to see your 220 at the wheels for 240 at the crank. Just one of the drawbacks of an automatic.
VR43000GT
10-15-2009, 11:01 PM
For a FWD car that was a manual and had 240hp you would see closer to 200 at the wheels. To only lose 20 hp on a 240 hp vehicle is almost unheard of.
TDWPgtp
10-24-2009, 06:18 PM
dont get me wrong, i love grand prixs, but is it just me or do our engines seem extremely inefficient. looking at some newER cars with similar size engines, ive noticed way more hp and way better economy. take the Genesis Coupe. it has a N/A 3.8 making 306 hp. thats 66 more hp from the same size engine with no S/C. ANDDD it gets better economy. thats just one example but i think you get my point. its just dissapointing to see how much more efficient other cars are. i want that kinda power and mpg! :uhoh:
BNaylor
10-24-2009, 09:05 PM
:confused:
Then buy the Hyundai Genesis Coupe or a car that wasn't first introduced back in 1996. :lol:
:confused:
robkiehl21
10-25-2009, 05:37 PM
You're forgetting that the 3800 V6 engine is basically a 40 year old design, it started out in the 60's (or 70's cant remember exactly) in buicks... It is an iron block pushrod 12 valve engine. The 3.8 in the genesis, or the 3.8 in the mitsubishi eclipse gt are aluminium and have 24 valves, as well as much more freely flowing intake and exhaust ports. Most newer engines also have variable valve timing, direct injection, and higher compression ratios. Personally, I am no fan of pushrod engines, but I love the 3.8 s/c in my grand prix.. Huge amounts of torque, and I get 24 mpg average, which for about 270 horsepower in mine, is pretty good in my opinion. You can't expect a 40 year old engine to compete with modern technology, but the 3800 has done pretty well, as it was one of the last pushrod OHV engines to still be put in cars (not counting the LS series v8s), only being discontinued a couple years ago.
TDWPgtp
11-05-2009, 12:02 PM
learn somethin new every day i guess ha thanks
CrazyHorst
11-05-2009, 06:58 PM
Good info above. Just to add a couple of things...the iron-head hurts the peak hp performance of any engine because the engine is going to be knock limited (can't use full MBT spark advance as you'd destroy the engine). The pushrod valvetrain and relatively large 2-valve components limit the redline....although my personal belief is that the 3800 is the highest evolution of a pushrod valvetrain used in an iron-head engine (other that possibly some corvette derivatives...but I consider those anodized CNC rocker arms to be inferior for durability reasons over the nice investment-cast ones used in L36 and L67)
Back to the classic equation, HP = torque * rpm / 5252 (using SAE units). So imagine the horsepower you could make if you could spin the engine up to 14000 rpms...you get the picture that there isn't any free lunch.
What a 3800 has is lots of torque as mentioned. The supercharger only helps. Personally I think you get very excellent fuel economy with a 3800 of any variety.
A couple of other thoughts relative to practical considerations...the 3800's emission performance is *excellent* compared to almost everything else out there. The short-iron-exhaust-port keeps a very large amount of heat in the exhaust stream which helps catalysts out. Also consider that the 3800 was made at a peak volume of nearly 5000 engines per day out of a single manufacturing plant, all with net-build (unlike some manufacturers who batch-sort parts based on dimension..nice to do but forget about volume)...I don't think you'll ever see that again from anyone else.
Another mistake is to think that each aftermarket mod is additive to total hp. That was one dyno run my friend...and nobody will ever know whose lunchbox was on the torque-reaction-arm while the dyno was calibrated or what kind of perfect moist-air sea-level standard-air device was used to feed the engine.
But what we're getting at here is the reasons behind the end of the 3800....relatively large mass...and the engine is never going to be 300hp advertised without aluminum heads, etc....or 50 degree water-to-air intercoolers....or 102 octane gas...the numbers on those get close. The public doesn't care, they want to compare vehicles on peak HP numbers and not what the cage can do.
CrazyHorst
11-05-2009, 07:27 PM
Also...just recalled...the L67 was somewhat in response to Ford's 3.8 Tbird SC which came out earlier and later on the SHO. The 3.8SC was a catastrophe in packaging with pipes, hoses and tubes running all over the place. The boys from Flint popped it on top of the balance shaft and said how ya like me now? :D A supercharged engine don't need a fancy intake manifold. ;)
Huge cost savings in production volumes nonetheless.
CrazyHorst
11-06-2009, 08:51 PM
Just to underscore one more point...a 4-valve head has a huge advantage in "volumetric efficiency" due to the valve area....or in other words it "flows" a lot better at higher RPMs. In a 2-valve head, the mixture-motion or "combustion chamber swirl" which induces excellent low-end torque becomes a restriction as flows increase.
The downside of the 4-valve head is that with all that valve area there's equivalently more "spitback" of essentially EGR when the intake valve opens with a partial vacuum on one side and low-positive, but near-atmospheric exhaust pressure from the last combustion event. Essentially the 4-valve has considerably more "EGR" at low rpms which is directionally wrong for producing torque.
The other issue is most 4-valves I've been near with appropriate instrumentation went quickly to piston protection (overfueling) partially due to the valve reliefs and sharp edges on the piston face. Waste of fuel integrated over a long time.
This isn't to say one is better than the other, IC engine design is about tradeoffs and balances, there is no free lunch so to speak. Just developing a engine-hardware and control package with a nearly flat and not super-peaky torque curve is a huge challenge in itself. Then comes durability, sealability, emissions, fasteners, manufacturing all the components to dimension, assembling the product...lots and lots of engineering development behind any powertrain after you get past the IC theory "pathway" which has been chosen.
Fastlane89
03-06-2010, 05:31 PM
^^^ Better technology = better effeciency. The GTP GP was probably top of the class when it was first unveiled in terms of torque and HP...some V6's still dont stack the same kind of HP and torque, though 300+ HP 6 cylinders seem to be setting a standard these days.
Oh and by the way, unless your planning on racing the Nurburgring, i wouldnt focus so much on horsepower as i would on torque. Increasing the torque will not only leave those pathetic jap-craps in the dust, it will make them never want to screw around with another American again.
BNaylor
03-07-2010, 10:30 AM
:rofl:
Thats why I like watching the Fast & Furious movies in Blu-Ray of course. :grinyes:
But I have my own experiences blowing the doors off of 350Zs and G35s just to name a few :loser: with my GXP.
:rofl:
l67cooled
03-16-2010, 02:55 PM
I'm surprised no one mentioned how all dyno's are a bit different; especially when comparing a dyno jet to a mustang dyno. Some dyno comparisons have varied up to 10% difference. You really can't compare to other dyno's you've read. Although you can see your difference if you continue to mod and use the same dyno.
If I remember right the stock 4t65-hd will roughly loose 15 to 17% hp from the crank to the wheels.
OP if you pulled 240 whp with the little bit of mod's you've added then I'd say you did pretty well. You have to realize not all your mods are adding much HP if any at all.
