1999 taurus wagon
elwagner
08-31-2009, 03:55 PM
How do I remove drivers side lamp assembly without breaking it? I have remove the two srews but the assembly still seems attached.
shorod
08-31-2009, 07:56 PM
Welcome to the forum!
Which driver's side lamp assembly? Headlamp, parking lamp, tail lamp, etc?
-Rod
-Rod
elwagner
08-31-2009, 09:14 PM
-Rod
Tail light
-Rod
Tail light
GPFred
09-03-2009, 01:18 PM
If it is anything like a sedan, you'll need to take off the paneling on that side inside the back area and you'll see the nuts holding the tail light assembly to the vehicle. It can be a PIA to do. It requires a 10mm deep well socket to get some of the nuts off, then housing comes away. You'll have to disconnect the plugs that connect to the light sockets. Good luck.
elwagner
09-04-2009, 10:41 AM
It is not like the sedan. There does not seem to be any access to the tail light assembly from inside the vehicle. On the drivers side there is a spare tire housing that is lined by welded sheet metal and no access to the relase the light assembly.
shorod
09-04-2009, 08:07 PM
There are push pins holding it that may make it feel like it's still attached. From the factory service manual:
Removal
1. Open liftgate (40010).
2. Remove two screws from rear lamp.
3. Pull front section of rear lamp away from vehicle to disengage pushpin retainer.
4. Push rear lamp rearward away from vehicle.
5. Lift tabs on park lamp connectors and pull connectors away from parking lamp socket and wiring.
-Rod
Removal
-Rod
