AIR DRIED BEEF DOG FOOD
2002 300M fuel gage
CathyDad
08-25-2009, 10:22 PM
My fuel gage started dropping to "E" around 7/8 tank, returns to normal operation at 1/2 tank. I believe I either live with it or change the expensive sending unit/pump assembly. Is it necessary to drop the tank or did Chrysler provide an access panel? Any help is appreciated.
tinmanwpk
08-26-2009, 09:29 AM
Yes, you have to drop the whole tank.
CathyDad
09-01-2009, 11:29 AM
Thanks--pretty much what I figured. I just received a shop manual on disk and will take a look see to make a decision on whather to do it myself or pay. I may also decide that the problem is not so serious after all. Normally, I have always had to use longer replacement hoses in order to reinstall--I guess the tanks must be placed early in the build. I do like a challenge. And my wife likes the car.
tinmanwpk
09-01-2009, 12:09 PM
You can use the OTIS/EVIC overhead computer for Distance To Empty in addition to the fuel gauge. Also, does the "low fuel" light come on? You should have a couple of gallons left when it does.
You could also have a loose wire somewhere or bad connection at the fuel pump.
Be sure to get the proper pump for your car if you decide to replace it. '99-'01 and '02-'04 are different.
cocks12
01-12-2011, 11:04 PM
Must be the fuel tank is full. or check the valve. due to fuel leakage it smells like gas in fact. and the fuel pump might be loose connected.
