2004 chrysler 300m
solbrova
08-13-2009, 02:52 PM
i have the following fault codes: p0058, p0340, p0441, and p0344. i have very minimal engine knowledge, but the drive and desire to do it myself due to a love for wanting to gain the knowledge. any and all help and advice you can give would be greatly appreciated
tinmanwpk
08-15-2009, 01:08 PM
You have an Oxygen sensor problem with 58, but nothing major. Downstream , I for get which side. Easy to change, but will do no harm in the meantime.
340 and 344 are your camshaft sensor. Happens to lots of us. Need to change it out.
441 is evaporator purge. Could be something as simple as your gas cap not on tight. Check that out first.
cocks12
01-12-2011, 10:02 PM
I would suggest you to replace with the new one. and check if it working fine. there must be a problem in the sensor.
