2004 malibu classic odo and speedo not workin.
stumpy-1
08-04-2009, 05:14 PM
Replaced cluster you can read the miles but it does not turn. And the speedo does not work. But all other guages does including the tach. HELP!!!
Johnny R
08-05-2009, 10:35 AM
Is the needle stuck below the pin?
thisnametooktolong
08-05-2009, 02:11 PM
I am assuming that the car you are looking at is not a CAN compliant car (I believe that was not, but not sure)
Chances are that if you do not have a check engine light, the cluster is bad or the wireing is buggered up via a bent pin or a bad pin. ( is that cluster new?) Just to make sure that you don’t have multiple problems like the Mil is not working I would jack in scanner and take the car for a drive check to see if the MIL was on and monitor the speed sensor. A good scanner will read out in MPH or KPH. That checking OK, I would back probe the drive ckt to the cluster to make sure that it had a good signal from the BCM/ECM. To power the Speedo/OD. You can actualy do every thing on jack stands. Keeps you from getting pulled over for dialing a cell phone
been there done that
