'94 Skylark 6cyl Won't run in drive, but will in D3..
kywin
07-29-2009, 08:33 AM
Car slowed suddenly and started making clicking sounds in drive. Will drive slowly in lesser gear. Is this a transmission issue and should I flush it and install new filter before anything else? Thanks
MagicRat
07-29-2009, 10:52 PM
Likely it is a trans issue, and my guess, in this case, a flush and filter will not help. Probably there is some internal damage, which can only be fixed with a rebuild or getting a used replacement trans from a wrecking yard.
I suggest taking it to a transmission shop or mechanic and see what (s)he says. If you like, let us know so we can tell you if it sounds legit.
