Grand prix starting trouble
matouk313
07-28-2009, 08:48 PM
I went to start my car and turned the key all the way and it kind of hesitated to start and then klunked out. I then tried again and it did the same thing except the light flickered also. I gave it one more shot and it didnt even make a starting noise. I then got out and popped the hood (with the keys out) and it sounded like the engine was running. even tho nothing was on. I then went home and came back in 15 minutes and the noise or what i thought was the engine was gone. It also smelled like kind of something had been burning like electrical perhaps. I then put the keys back in and tried staring the car and the keys turned all the way with no sign of a start and all of the lights were coming on. I have also had problems with the ignition to where the keys always get stuck in the iginition(if that helps figure this SHYT out) thanks.
tblake
07-28-2009, 09:18 PM
What year? Model? and how many miles?
Sounds like it could be a starter issue. I would start by cleaning the corrosion off the battery cables, then have an assistant crank the motor and check for voltage at the purple wire on the starter.
matouk313
07-29-2009, 01:28 AM
i just took apart both and rubbed a little sand paper and connected them back together and i got the same thing once again. key turned all the way and no start.
the year grand prix is 2000 2dr gt 108,000 miles
richtazz
07-29-2009, 12:16 PM
have you had the battery tested?
