Front Wheel Bearing problem
KansasZj09
07-25-2009, 01:48 AM
:confused:My 95 GCL has play in the front drivers side wheel area, we jacked it up yesterday, and could move the tire up and down, my mechanic doesnt think its a ball bearing, but a wheel bearing bc the ball joints dont move at all, however i hear this whining noise, and i checked the fluid in the transfer case it was low, but filled that up, still have noise, he says i may need to pick up a new hub, i was just wonderin could this cause the jeep to whine when i accelerate? it whines when i put it in gear, if i put it in reverse i can hear the whine the best, even if i hold my foot on the brake, i put it in neutral and the jeep doesnt make the whine noise, just in gear, it does it in drive whenever i give the jeep gas, im stumpped any ideas?
ozlander
07-25-2009, 06:32 AM
Try also to check the bearing guide of the pulley. I also experienced whinning sound when accelerating with GCL but it was reduced when i cleaned the bearings with WD40 and put grease as well.
KansasZj09
07-25-2009, 12:30 PM
do you remember where your whine noise came from? like the area? mine sounds like the transfer case though.
rhandwor
07-25-2009, 03:50 PM
Put the vehicle on four jack stands. Use a stethoscope and listen at various points along the drive line. The vehicle has to be in 4wd so you can listen if you have bearing noise.
http://www.autopart.com/tools/toolsmain/tool/T_2015.htm
KansasZj09
07-27-2009, 03:24 AM
I put the Jeep in 4 wheel drive, not on the stands yet though, but it seems like the 4 wheel drive works, the vic says that i need to service 4x4 switch, but thats only when i put it in 4x4, and the vic also says that the front two tires are engage, if it was a tc problem wouldnt that only be when i put in 4 wheel drive? i also do have a front wheel bearing problem i just need to replace the hub, the whine comes from the front/center of the jeep, the hub is being replaced on the drivers side in the front
dksob81
07-27-2009, 10:56 AM
yes a wheel bearing will give you a whining noise. most of the time - not all the time - the wheel bearing will have play in it, jack the jeep up and grab the top and bottom of the wheel and rock it back and forth - if you feel play it is either the balljoint or wheel bearing, but most likely wheel bearing.
