95 Camry 2.2 #1 Speed Sensor
JennyDee
07-22-2009, 10:20 PM
I'm getting a trouble code 42 along with the speedometer gauge not working and it points to #1 speed sensor. I want to test the voltage to terminals 1&3, which should change from 0 to11 volts. The problem is that I can't remove the speed sensor to test it. I removed the connector along with the the (1) bolt but the sensor does not move and I can't see any joint to pry between. Is there a second bolt that I am missing or is there a method to break it free? I'm trying to access it from under the distributor and there is not much room.
jdmccright
07-23-2009, 11:52 AM
There are three bolts that hold the sensor in place in a triangular pattern around the connector.
As an alternative, or before you kill your knuckles, go to the sticky at the top of the forum and d/l the portion for the 5S-FE engine (EG1) and for Body Electrical (BE). There is an inspection procedure in the engine section for testing the sensor without removing it, starting on page EG1-382. If that fails, then you can remove it and check it per the instructions on page BE-67. Hope this helps!
JennyDee
07-24-2009, 09:29 PM
The information was very helpful and specific to check the #1 sensor. I hand to have someone else remove the sensor as I could not pry it off myself.
Thank you for taking the time and pointing out the info in the manual. I have to say that the downloaded manual is more specific that the Haynes Repair Manual that I have been using.
The sensor solved the problem. A little pricy at $220, but the 95 Camry with 208K is back on the road.
