2000 Blazer 4x4 problem
biker1
07-12-2009, 06:56 PM
I can't get my 2000 Blazer to go into 4 wheel drive. When the car is in park nothing happens (no lights or noises) when I press 4HI or 4LO. When I put it in Neutral and press the 4HI button, a clicking noise comes from the TCCM and both the 4HI and 4LO light flash for a few seconds, then go out. The car is still in 2 wheel drive. Suggestions?
MT-2500
07-14-2009, 08:41 AM
We need to know which transfer case you have?
Auto 4W or just the regular?
biker1
07-14-2009, 12:41 PM
It has just the regular transfer case. There is no check engine light showing.
MT-2500
07-14-2009, 01:29 PM
Ground pin 13 on the diagnostic connector and turn key on and read codes from shift button lights.
Post back codes.
biker1
07-14-2009, 03:12 PM
Sorry, but I'm not a mechanic and don't have a "diagnostic" tester. I plan to bring the car to a local garage but don't want them to start replacing part after part until the problem is fixed. Wanted to "guide" them a little bit in the hope of limiting my costs. Thanks anyway.
MT-2500
07-14-2009, 04:17 PM
All you need to get codes is to ground pin 13.
MT-2500
07-14-2009, 04:20 PM
http://www.automotiveforums.com/vbulletin/showthread.php?t=572914
