Engine Swap...
Dodge426
07-10-2009, 07:39 PM
Hello Guys! How hard is it to Swap the 3100 Series Motor out of our 1999 Chevrolet Lumina for a 3800 Series Motor?
maxwedge
07-11-2009, 02:48 PM
Subframe, computer and harnesses, trans and axles, exhaust and lots of other " stuff" better off looking for a 99 LTZ.
Dodge426
07-12-2009, 12:52 PM
how much bigger in size is the 3.8 compared to the 3.1? is it worth doin the swap or not?
maxwedge
07-12-2009, 06:42 PM
.7 liters, no? About 42 cubes , 40 hp, and lots more torque, not worth the work, another car is much more advisable.
Dodge426
07-12-2009, 06:48 PM
Can you explain the work that is needed? I found a Lumina with one, but not sure what body and frame is like. Can i take the whole front end and put it on ours?
maxwedge
07-13-2009, 10:01 AM
Yes, crossmemnber, axles, trans, everything I listed, again a major project!!!
Dodge426
07-13-2009, 10:04 AM
So its not really worth it? how much money you think it would take to make a stock 3.8 a suerpcharged 3.8 as wel as a cam switch and all that litle stuff
maxwedge
07-13-2009, 10:14 AM
The blown 3800 is a different short block, you cannot do this with the std K engine.
bigbadbronxy2k5
07-13-2009, 12:09 PM
The blown 3800 is a different short block, you cannot do this with the std K engine.Get a top swap kit. includes heads, supercharger, intake, etc.
Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.11) Sprint PPC6850SP
Dodge426
07-13-2009, 01:27 PM
how much dsoes that kit cost?
bigbadbronxy2k5
07-13-2009, 04:20 PM
Ok, first off you will need to do a 3800 Series 2 3.8 normally aspirated swap and then you can use this http://www.milzymotorsports.com/ search for the top swap l36 to l67. Its about 1350. Hope this helps. Unless you can find a Supercharged 3.8 then you're good.
