help from stealthee
zerotohero192
07-09-2009, 02:16 AM
94 base thats reliable for a vr 4? somethings fishy. help please.
quackmandude
07-09-2009, 03:18 AM
whats the qiestion?
SAMSUNG-SGH-I617/1.0 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.6)
vr4choke
07-09-2009, 04:07 AM
^what he said^
are you talking about trading a 94 base for a vr4?
VR43000GT
07-09-2009, 11:52 AM
I believe he is asking about a possible trader or trade and cash for his base for a VR4. Unfortunately none of us can help you out unless you first, write in a more coherent manner, and secondly, give us far far more details about each car and the situation you are in.
vr4choke
07-09-2009, 12:41 PM
yea we definitley need a lot more. btw sl300gt, how are those iridiums working for you? any problems?
VR43000GT
07-09-2009, 01:50 PM
They have worked perfect since I installed them. I've never had any trouble with spark blow-out as they have run very smoothe under all conditions.
zerotohero192
07-09-2009, 03:10 PM
sorry i was on my playstation when i wrote that. here's the stats of his '91 vr-4:
Lower mileage engine (70kish on it now)(professionally installed)
Tranny was gone through 10k miles ago and had a 300m 25 spline outputshaft put in (1200 in PARTS alone and was worked on by Ries Transmissions in St. Paul Park)
HKS Exhaust
HKS Turbo Timer
Joe P MBC (has been set at 10 since install for my wallets sake)
SS downpipe (was on car when I bought it, front pre-cat delete)
Rear precat gutted
Radiator
O2 sensor
Rear aws lines replaced
K&N intake
Polished Plenum
Polished Y-pipe (3-2 3/4 coupler)
255 lph Wahlbro fuel pump
8an braided ss fuel line (sitting in trunk)
60k maint done when the engine was put in
3SX lightweight stock size crank pulley
Datalogger
Tinted taillights, 3rd brake light, and front turns
White headlights (can't remember brand at the moment)
Battery
Oil pressure sensor
'99 3mm Lifters
Iridium spark plugs (NGK)
10.2mm wires
New front axles
clutch slave cylinder
afr gauge, boost gauge, gauge pod
Superchips ECU (has timing control, although I left everything alone)(also replaced 2 of the capacitors as a precaution; I didn't want it to happen again...)
Have a replacement set of fog lights since one of the lenses is cracked
Replaced the seats with better shape used ones
Active Aero works as does ECS
yes this is a trade plus cash, not sure how much. mine is a '94 base 171,000 on motor and less than 10 k on clutch. chassis is pretty good. motor for the sunroof is shot.
HKS Exhaust
HKS Turbo Timer
Rear precat gutted
Radiator
O2 sensor
K&N intake
Polished Plenum
Datalogger
Battery
Oil pressure sensor
'99 3mm Lifters
10.2mm wires
New front axles
vr4choke
07-09-2009, 11:49 PM
hmmm sounds too good to be true. is this a guy in your area?
quackmandude
07-10-2009, 08:59 AM
unless its the base and alooooot of cash lol
Girly VR-4
07-10-2009, 09:33 AM
something is wrong with the vr-4 that he's not telling you about.
vr4choke
07-10-2009, 01:27 PM
lol maybe he has a fetish for 2nd gens. i know i do :naughty:
zerotohero192
07-10-2009, 09:21 PM
yeah he's a guy in my area. i know he wants around $6000 i think? anyways is it a lot cheaper to maintain a base over the vr-4? that's probably why he wants to trade. either that or something is wrong. do any of you guys know roughly what the difference would be to maintain a vr-4 over the base per month?
VR43000GT
07-10-2009, 10:13 PM
VR4 is more expensive all together. It must have premium fuel, has more parts that need serviced, has a more expensive drivetrain, etc. If the VR4 is in good shape and remains reliable it shouldn't be all that much. However, if things need fixed or things start to break you will need to have some money set aside for that as it is not cheap. For me, I do not cut corners. I use Royal Purple oil that is spendy to say the least, drive to Iowa to make sure my VR4 gets 93 octane instead of 91, etc. Then agian, I am somewhat nuts.
Stealthee
07-10-2009, 10:38 PM
I see everything has been covered and my service is not needed here. :p
vr4choke
07-11-2009, 02:50 AM
well if he wants 6k then its not that great of a deal. i'd keep yours if it were me
Stealthee
07-11-2009, 11:29 AM
I disagree. $6000 for that VR4 is a good deal as long as the car looks the part as well.
vr4choke
07-12-2009, 12:32 AM
but 2nd gens are the best. . . i dunno. it sounds like a good deal financially and whatnot. but pop-up lights are lame :icon16:
AutostradaVR4
07-12-2009, 05:56 AM
Hey screw you buddy! pop-up light are the shit! In the words of the great Jeremy Clarkson;
"And [the Porsche 944] had pop-up headlamps, which no car has anymore these days. There are lots of things from the past that we dont want back....But pop-up headlamps they're just so COOOOL!"
vr4choke
07-12-2009, 05:11 PM
eh. i like em in the daytime or when theyre down. and snake eyes are awesome. but i hate how they look when theyre up. i just look at the front end with the lights up and lose my ability to take life seriously
