02 Bravada radio no sound
prix50
07-08-2009, 07:05 PM
My 2002 Bravada has no sound coming from the radio. It's as if someone has hit a MUTE button. The radio, speakers and amp have all checked out fine. The stations show up and CD's are shown and everything operates, just no sound coming out..
Any suggestions?
Chris Stewart
07-09-2009, 12:27 AM
It's a long shot but sometimes electronic devices benefit from a reboot. Disconnect the negative battery cable for 20 minutes then reconnect and check your radio volume.
Best007
07-11-2009, 11:01 AM
Any suggestions?
I presently have the same problem with the same Bravada and I think with my research that the amplifier.
http://www.the12volt.com/installbay/forum_posts.asp~TID~114675~PN~1
I'm sure to 99% if you change that for the sameone all was ok but if you bypass or change for another model you lose all warning sound and on star voice.
Let me know your progress
Thx
Frank
ericn1300
07-11-2009, 08:25 PM
Any suggestions?
Did this come out of the blue or was there any other work done just before it happened?
All the speakers have a different feed but all use a common ground back to the radio (not a body ground). Since the stereo has a display you know the body ground for power is good so start by checking if the stereo ground is good at the plug on the back of the radio and check to see if you have a short to body ground. A continuity check from any speaker ground wire to a chassis ground point should be less than .03 volts.
Best007
08-13-2009, 04:58 PM
Thx
Frank
I don't know if you've find the problem... but me I've change the amplifier and all are OKKKKKKKK
bhart2489
03-10-2010, 12:01 AM
the best thing i can say to do is get a new head (radio) they start at $50 and a half way decent one is $75 iv been installing car audio for 5 years now and am mecp certified, had the same problem when i got a 98 bradava stuck a new head in it and ran fine
