Fuel problem
kjwills
07-05-2009, 04:43 PM
I have a 98 Bravada. Last year I had the fuel pump replaced and it cost me over 700 dollars. I am experiencing similar problems. When I try to start the vehicle it just cranks it wont start unless I pour some fuel down into the carburator. Then it will start and run great. If I shut it off, it will start if I try to start it within an hour it will start. but if I wait several hours or the next morning the same thing happens. the fuel pump is about a year old. could it be the fuel regulator. I didnt replace the fuel filter. I measured the fuel pressure at the shrader valve behind the intake and got about 52 psi. Any suggestions. kjwills
Chris Stewart
07-06-2009, 10:24 PM
Sorry KJ but the fuel pressure spec is 62 to 66psi. You might try to get it up with a new fuel filter but at idle or just a turn key test, there's not much flow to be restricted.
old_master
07-08-2009, 07:59 PM
I agree, key on engine off, fuel pump running, pressure should be 60 to 66psi, and it must remain above 55psi for 3 to 5 minutes after the fuel pump shuts off. If it doesn't pass both parts of that test, there is a problem and more diagnosis is necessary to locate the problem.
