Spark plugs
Extinct SS
04-02-2003, 11:24 AM
Whats the best spark plugs for a 94 Q45t with a V8? Thanks in advance.
maxnix
05-24-2003, 09:20 PM
OEM NGK only.
www.infinitipartsusa.com
JB666
07-13-2003, 01:41 AM
Is that all or your personal preference?
What is that actual model no of these sparkplugs?
Thanks
olu40
09-30-2003, 01:02 PM
Call the dealer for the correct model no but I believe it is PFK-6 or something. Not many spark plugs run good with the Q. It is a picky beast.
maxnix
10-13-2003, 04:38 AM
ThanksShould be specified in your owner's manual. Never use Bosch.
JB666
10-13-2003, 04:42 AM
Not everyone has manuals
JB666
10-13-2003, 04:43 AM
Ensnareyou
10-18-2003, 06:44 AM
NGK or Nippon Denso Iridium spark plugs work best but Bosch will work as well. I've found the Japanese made spark plugs seem to last longer so I'd recommend spending the extra money on them. Any good auto parts store (Kragen, Autozone, Napa, Pep Boys, Car Quest) will have the correct part number for the plugs but most don't stock NGK or Denso plugs so you'll need to order them. Your local Infiniti dealer will most likely stock the plugs but you'll pay more if you buy them from the dealer. Expect to pay anywhere from $7-$11 per NGK or Denso Iridium plug dependent upon where you buy them.
maxnix
10-21-2003, 01:53 PM
Bosch will not work! Electrodes will break and ruin the engine!
Anyone can get a manual if your car didn't come with one used. Ebay usually has the smaller bible ones and www.nissan-techinfo.com/infiniti/ will allow downloads in Acrobat format, along with all TSB.
flyinlouis
10-28-2003, 06:47 AM
I'm running the Bosch spark plugs platinum +4 for a year and it worked well and smoothly so far. The car always started in cold weather (we had -28 degC or -18 DegF last winter in Montreal, P. Quebec) and it started without problems.
Louis / 1994 Q45
maxnix
11-03-2003, 06:11 PM
I'm running the Bosch spark plugs platinum +4 for a year and it worked well and smoothly so far. The car always started in cold weather (we had -28 degC or -18 DegF last winter in Montreal, P. Quebec) and it started without problems. - Louis / 1994 Q45
The problem is not the starting, but the electrodes breaking off into the cylinders. Then the car has starting problems.
Read the posts at NICO.
Jeff Williams
12-15-2003, 07:13 PM
Louis / 1994 Q45
I used to run the BOsch plugs. I have been using them for 20 years. Never a problem. Not until I put them in the Q. Burned the electrodes off of one plug, and nearly ruined the injector. I almost was stranded, and nearly spent several hundred at the dealership. The plug nearly burned up the coil pack. The plugs had 60,000 miles on them. When I took them all out, nearly all the electrodes were half the original size. The Q will literally burn the electrodes off.
Trust me, change them out. The plugs are NGK, platinum, I don't remember the part number, but infinitipartsusa.com has them, for a good deal, and once you get the part number, do a search on eBay. I got a set of 8, for $42.00
I will still use Bosch, in other engines, though.
Cartech
12-16-2003, 07:08 AM
If you have hard starting in cold weather from fouled out plugs use a higher heat range plug.
I believe their was a service bulletin on that.
