transmission fluid white
mrsbb
06-25-2009, 10:46 PM
99 ram--checked the tranny fluild and its white---any suggestions on what it is from and how to fix it?
redbovine
07-11-2009, 01:17 PM
you have water in the trans fluid. You need to replace the fluid soon to prevent damage. Also check any place water might be able to get into the trans so you can prevent it.
angus10
07-12-2009, 08:15 AM
It's not all that common but it does happen, the cooler on the side of the radiator where the tranny lines go in can spring an internal leak. Check the anti freeze and see if you notice any tranny fluid in it.
