starter replacement 2000 montana
amsoilman
06-25-2009, 10:04 AM
can anyone tell me which wires connect to the starter? pictures maybe?
1999montana
06-26-2009, 10:56 AM
I believe there are only two wires that go to the starter motor.
NOTE: I'm assuming that the battery was disconnected at the battery to avoid shorts.
1. The heavy 6 gauge red wire from the battery that connects to the large 5/16 bronze stud on the end of the solenoid
2. The smaller 18 gauge (don't know the color coding) that goes to the small terminal on the solenoid.
When the starter is dropped, pay attention to whether there is a shim between it and the engine block. The shim is necessary for proper alignment with the flywheel.
Have a look at this URL:
(click on the 'view job diagram' link to the right)
http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?displayName=Starter&currentPage=1&categoryDisplayName=Starting+%26+Charging&navValue=16400045&itemId=prod61198&parentId=cat30072
rockwood84
07-09-2009, 06:53 PM
3 wires on the big post 1 on the little post two bolts holding the starter on but you have to take the convertor covers off 3 screws
