TT motor swap q's
zerotohero192
06-24-2009, 10:52 AM
i'm receiving the tt motor next week along with the ecu, injectors, intercooler and wiring harness. what other parts do i need? also could i use the stock fuel pump if i had the boost around 9 psi? this is going into a '94 base, 5 sp man.
quackmandude
06-24-2009, 11:00 AM
not to sure but i think u need a tt pump man. also motor mounts and of course manifolds. i would invest in at least a tt radiator or aftermarket one also
SAMSUNG-SGH-I617/1.0 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.6)
Stealthee
06-24-2009, 11:12 AM
You need at least a TT pump. The motor mounts are the same but you need the TT front motor mount bracket. You also need a TT injector resistor pack, TT fuel pump relay, and TT MFI relay to go along with your TT wiring harness. Hopefully your TT engine comes with injectors too.
quackmandude
06-24-2009, 11:18 AM
o yea that what i meant, just the front mount
Stealthee
06-24-2009, 11:24 AM
Not the mount. The mount bracket. All 3s motor mounts are the interchangable across all years and models. The TT front mount bracket that bolts to the block is different to clear the turbo. Other than that the mount bracket on the transmissions differ from FWD ATX, to FWD MTX, to AWD Getrag trans, but the mount itself is the same.
quackmandude
06-24-2009, 01:28 PM
o, i learned something :)
hey man ake pics if u can when ur ding the swap, keep us up to date man.
zerotohero192
07-03-2009, 09:11 AM
i think the guy tried to burn me, thank god i still haven't given him any cash. but IF and WHEN the motor shows up i will take pics and keep you all up to date. thanks for the info so far.
vectorspecialist
07-05-2009, 12:52 AM
wouldn't he need a tranny or something to hold the power more effectively?
zerotohero192
07-08-2009, 12:11 PM
so the motor never showed up and the guy called demanding payment, i gave him the finger and said show me receipts. so this guy who has real parts and i saw them w my own eyes has the turbos, one manifold, heads pistons and rods. is it worth buying and trying to scrounge up other paarts for the conversion? does anyone else have the rest of the parts for sale?
toddrs93
07-09-2009, 05:15 PM
the n/a trans will hold fine at stock levels, and even higher depending on how hard its driven. We have a FWD TT with the stock trans from the SOHC in there thats been running for 2 years now, at about 300whp. Thats of course without launching or tracking it.
Stealthee
07-09-2009, 06:25 PM
The NA trans is very fragile.
I have fragged 3 diffs and a second gear. I bought one trans that was on stock TT power with a broken diff. I bought some trans stuff off someone else who broke one diff, replaced said diff with Quaife LSD then broke 2nd gear two different times.
quackmandude
07-10-2009, 09:09 AM
are all na tranys the same, dohc and single?
Stealthee
07-10-2009, 11:01 AM
For the MTX's 91-92 are one trans and 93-99 are a larger diff in the trans but SOHC and DOHC are the same.
For ATX there are more differences thru the years due to solenoids but SOHC and DOHC are still interchangable.
toddrs93
07-10-2009, 11:41 AM
no offense but I think you guys are kind of rough on the cars lol
quackmandude
07-10-2009, 12:45 PM
so for a tt conversion? neither 1st gen or 2nd gen tranny would be agood idea?
Stealthee
07-10-2009, 01:37 PM
My first diff died due to wheel hop, the second diff broke on its first launch, third diff broke on a drive home from work. I broke 2nd gear pulling out from a stop sign and getting wheel spin. I have the LSD now so 2nd was the weak point. This is all on NA SOHC type power
One of the broken diff trans I bought came from Jackie (GTOGIRL3000) and she broke hers as a result of wheel hop.
Mikes95RT supplied the other parts. After one broken diff he put in the LSD, then proceeded to break 2nd twice.
If you TT a FWD and don't use the power then whats the point of TTing it?
