98 Grand Am needs help!
rocketman4281
06-24-2009, 08:00 AM
My 98 Grand Am has some weird problems. One day it started kinda funny, ever since then it idles rough for about 10 seconds every time you start it(hot or cold),also the engine fan runs all the time. Sometimes when you stop it just dies. The temperature is right where it should be. No check engine light is on. Do I have a bad computer or what?
xeroinfinity
06-24-2009, 08:41 AM
Welcome to AF !!
Sounds like your experiancing a misfire. I'd get it scanned to check for codes, your check engine light may not come on and still have a DTC.
With your fans running all the time, could be the relays bad, or your coolant temp sensors bad.
With the dying when you stop, if you put it into neutral when you stop will it stay running ?
This could be a TCC solenoid in your trans causiing this.
