Security LED
chrisanthony
06-22-2009, 08:21 AM
Hi everyone
I just purchased a LED Varad Scanner. Is there a way to hook it up behind my radio so it can only come on when the engine is off?. It has 3 wires 12V(constant)/ground and yellow. I have it hooked up on the constant radio wire for now, but very distracting when driving at nite.
Thanks.
Chris
96 escort lx
Selectron
06-22-2009, 11:56 PM
I'd guess that the yellow wire might be for that purpose, so I assume you didn't get installation instructions with it. If there's a model number on it, it might be worth checking the Varad website and see if the instructions are available there.
If you have to do it with two leads though, it can be done. You could use a relay, and wire it such that the contacts would be held open while the ignition is switched on, closing when the ignition switches off, thereby completing the circuit automatically. You would just route either the 12V wire or the ground wire via the relay's normally-closed switched contacts. That's kind of a clumsy solution though.
If the unit is intended to be operational when the ignition is switched off then it presumably doesn't draw much current. If that's the case then there's a neat way to wire it, by connecting the 12V wire to a constant 12V feed, but then instead of connecting the ground wire to ground, connect it instead to the top end (the 12V end) of a relay coil, but it must be one which is fed with 12V any time the ignition is in Start or Run - you don't have to add that relay - I'm talking about one of the relays already fitted in the car. When the ignition is switched on, the 12V wire would then have 12V, and the ground wire would also be sitting at 12V (because it's at the top end of the relay coil) so there would be 0V potential difference between the two wires and thus the unit would be switched off. Then when you switch the ignition off, the top end of the relay coil would fall from 12V to 0V and would effectively become a ground point, and the unit would automatically switch on. It wouldn't be a true ground because you would have the relay's coil resistance in series, but for a low current device that isn't necessarily a problem; it depends on the unit's current consumption, and the resistance of the relay coil.
I'm on a new computer and I don't have all my programs installed yet so I can't see my wiring diagrams for your model, but when I get that sorted in the next day or two I'll take a look at them, and I'll sketch a couple of diagrams for those two methods, which will be easier to follow than the written explanation.
12Ounce
06-23-2009, 06:37 AM
Clever! It might be wise to install a diode in the original coil 12v circuit ... to eliminate possible back-feed. Depends on nature of circuit.
chrisanthony
06-23-2009, 12:18 PM
Hi man thanks...i couldn’t find any instructions but I’ll try hooking the yellow wire up..to the black ground wire from the stereo. The steps you mentioned is this all concentrated on the ignition in the steering column? The electrical system is pretty new to me..i really don’t want to mess anything up.. I'm pretty comfortable with the radio electrical cuz if anything goes wrong i can just change the fuse.
Selectron
06-23-2009, 01:03 PM
Thanks 12Ounce, a blocking diode might indeed be a smart idea; I hadn't thought of it yet.
No, don't connect it to the radio's ground wire, because that's always at ground potential regardless of whether the ignition is switched on or off, so it won't achieve anything and it certainly won't make the unit switch automatically. I imagine that yellow wire might be intended to hook into the alarm system, so the unit would switch on automatically when the alarm system is armed.
I got my computer all finished so I can take a look at the wiring diagrams later. Oh yes, one other option would be simply to wire it via a switch, maybe a hidden one, and just switch it on manually when you park the car. I'll see if I can find an easy automatic switching solution in the area of the radio though.
chrisanthony
06-23-2009, 03:30 PM
hey..i was just thinking how bout the ignation wire going in to the radio?..could i tap into that?..but then again it only goes live when the key is turned...:(
Selectron
I'm just reading this pdf file (http://www.varad.com/v4/pdf/IM-SCANNERSVSX50.pdf) on the Varad website. They are referring to the third wire as orange, but aside from that does it look like those instructions might refer to your unit?
Reason why I ask is, it says the unit is programmable, to select the flash sequence and the speed. It also says that if the 12V wire loses contact even momentarily, it will lose its memory and you'll need to go through the set-up sequence again. Same thing would apply if the ground connection was momentarily interrupted.
That means you can't wire it in via a switch, nor via a relay, nor can you use the ground-via-relay coil idea which I mentioned because in all cases the memory settings would be lost each time it was switched off.
Therefore it would need to have a constant 12V feed and a constant ground connection, with on/off control being achieved via the third wire. The unit is active when the third wire is grounded, and inactive when it isn't - well, that's the case for the units in that pdf.
Unfortunately, there's one detail which they've omitted, which is whether it's permissible to allow the third wire to toggle between 12V and 0V, or whether it may only toggle between an open-circuit condition, and 0V.
If the former, then that's easy to do by using the ground-via-relay coil arrangement, and I doubt the relay coil resistance would even be an issue. If it must be the latter though, then for automatic switching, that would require that you add a single-pole, double-throw (SPDT) relay, wired such that the third wire would be held in the open-circuit condition when the ignition is switched on, and then grounding via the relay's normally-closed contacts when the ignition is switched off. That's simple to do, and I can draw a sketch of how to do it, so you'll be able to do that without any problems. Or of course you could feed that wire to ground via a switch for manual switching.
I think we need to find out more about that third wire before we can proceed though. Is your unit similar to those on the pdf, or do you have a model number for it?
chrisanthony
06-23-2009, 05:21 PM
Hi selection thanks for the reply..yea its exactly the same except mine isn't programmable so i'm not worried there and the yellow wire is exactly what the orange wire states in the pdf. Also when they say "Ignition - Ground when engine is “OFF”.
(See fuse box)" what does that mean? where would i hook it up to the fuse box?
Selectron
06-23-2009, 07:01 PM
Can I just check something? You have the red wire connected to a constant 12V, and the black wire to ground, and the yellow wire isn't connected to anything but the scanner works when it's wired up that way, yes? Works fine aside from the fact that it doesn't automatically switch off of course - is that correct?
Selectron
06-23-2009, 07:39 PM
I'll assume that my last post above is correct - if so then that means the scanner is working without having the third wire grounded! I think that instruction sheet is badly worded - it isn't so much that the scanner will switch on when the third wire is grounded, but rather it will switch on in the absence of 12V, so it doesn't matter if it's grounded or left floating (open-circuit) - just so long as 12V is no longer present, the scanner will switch on.
That means you can do all your wiring at the back of the radio, because you have a constant 12V feed there, and a switched 12V feed (hot only in Acc or Run) and a ground wire. So your red wire goes to constant 12V, yellow wire to switched 12V, and black wire to ground. No need for extra fuses, because you have the two radio fuses already in-circuit.
You might want to prove that to yourself before wiring it all up - touch the red wire to 12V, black wire to ground - the unit will work - then touch the yellow wire to 12V, and the unit will switch off. Remove the yellow wire from 12V and it will switch on again.
So when you've done the installation, the scanner will be off when the ignition is at Acc or Run, and will switch on automatically when the ignition is switched off.
You'll find that the scanner will light up briefly while you are cranking the engine - the radio always switches off for a second or two during cranking, eh, so that means the scanner will switch on during that same brief period.
If you're sitting parked in the car with the engine off, then to save the LEDs from giving you a migraine, just set the ignition switch to Acc, and the scanner will switch off.
I reckon that's all there is to it. You probably know the radio wire colours, but if not then here they are. I don't have wiring diagrams for the '96, but these are the wire colours for the '95 and the '97. One time when you mentioned wire colours for some problem or other, I noticed that those which you mentioned fitted in with the '97 rather than the '95.
1995 Escort radio power feeds:
Constant 12v - dark blue/red via the 'Room' fuse
Switched 12v - dark blue/black via the 'Radio' fuse
1997 Escort radio power feeds:
Constant 12v - blue/red via the 'Room' fuse
Switched 12v - blue/black via the 'Mirror' fuse
chrisanthony
06-23-2009, 08:14 PM
yes you are correct..that's exactly how i have it hooked up rite now...after i got home i saw the top led melted i assume that's due to directly being in the sun all day..what do u think?
chrisanthony
06-23-2009, 08:25 PM
I'm not exactly clear on this..what do u mean buy room and radio fuse..its through the fuse box? and would i connect a wire there?..
Just to make sure
12v red to constant radio
switched 12v yellow ignition ground to the ignition wire of the radio
black ground to ground of the radio
Selectron
06-23-2009, 08:36 PM
Crikey, that doesn't sound too good! The LED is unlikely to melt - if it got that hot then the semiconductor junction within it would simply quit and it would no longer illuminate - is it the unit's plastic casing which has melted rather than the LED itself?
Selectron
06-23-2009, 08:40 PM
Just to make sure
Yes, those connections are correct.
I only mentioned which fuses feed the radio for the sake of completeness. You don't have to go near the fuse box if you'd rather not - you can just splice into the wires at a convenient point behind the radio.
chrisanthony
06-23-2009, 09:04 PM
hi...i just came back in from trying what you suggested. I connect all the wires..12v led to constant (radio), yellow ground to ignition switch (radio), black to ground and the LED still seems to be constant even through the key is turned to on..just to make sure..i am splicing into the radio harness...
chrisanthony
06-23-2009, 09:05 PM
the plastic casing actually melted..but the leds do get kinda of hot..but not that hot to burn the plastic...
Selectron
06-23-2009, 09:18 PM
I'm convinced that applying 12V to the yellow wire should cause the unit to switch off. Try this: first connect the black wire to ground, then connect the red wire to the radio's constant 12V feed, and then also connect the yellow wire to that same radio constant 12V feed. That should cause it to switch off. If it doesn't then you're probably going to have to wire it via a switch or a relay.
chrisanthony
06-23-2009, 09:29 PM
how would applying 12v to the yellow wire cuz the unit to switch off?..
Selectron
06-23-2009, 09:39 PM
Either by forward-biasing a transistor within the unit, configured in such that it switches the unit off, or by having two points in the circuit both sitting at 12V, resulting in a 0V potential difference between them, and causing the unit to switch off. There are lots of ways to arrange it.
chrisanthony
06-23-2009, 09:44 PM
oh ic..i understand..thanks man..I'll try it tomorrow after i get home from work...
1) black on ground
2) 12v red and yellow on radio constant
Selectron
06-23-2009, 10:23 PM
I'm just checking out Google, and I see other people saying the same thing - red to constant 12V, black to ground, and yellow to switched 12V.
Take a look at post #3 on this page (http://www.clubwrx.net/forums/interior-mods/26513-simple-question-varad-led-scanner-yellow-wire.html) - yellow wire hooked up to radio fuse - i.e. to switched 12V, and the unit switches off when ignition is switched on - i.e. with 12V applied to the yellow wire.
Post #3 on this page (http://www.explorerforum.com/forums/showthread.php?t=37653) is by somebody who sold the units, and in post #8 he says to connect the yellow wire to a switched 12V, and then post #9 confirms that it worked.
If applying 12V to the yellow wire doesn't switch it off, then try connecting the yellow wire to ground instead and see if that switches it. I can't believe somebody is manufacturing and selling these things and not providing adequate installation instructions.
chrisanthony
06-24-2009, 08:26 AM
for the switched 12v that would be something like the radio fuse rite..
does it matter if the switched 12v turns the a component(radio) off or on when ACC is applied?
Selectron
06-24-2009, 02:13 PM
Any switched 12V source would do, so yes, the radio switched 12V would be ok.
No, that doesn't make any difference at all.
Actually though, you have already tried applying 12V via the radio's switched feed and it didn't work, so the only other thing left to try is to see if grounding the yellow wire will cause it to switch.
If it doesn't then you can still get automatic switching but you'll have to do it via a relay.
chrisanthony
06-25-2009, 07:55 AM
hey guys how’s it going?...just an update..i connected the 12v to constant,yellow to ignation, black to black and its working perfectly now. The problem was the actually LED circuit was not good so I took it back and got a new one...
Thanks again for all the help guys...
I dedicated my cardomain page to you guys at Automotive forums and I'll be posting new pics up soon..
