wet carpet on pass side ??
kitchen sink
06-19-2009, 05:12 AM
Hello all. ( 2000 grand prix / 3800 non s/c ) just found out yesterday that the carpet on the passengers side / front, is wet. also noticed the garage floor was dry where there is usually a puddle of water from the air conditioning. is there a drain somewhere for the a/c that could be plugged? i wouldn't know where to start looking. any help advice would be appreciated. ...thanks...
brcidd
06-19-2009, 09:12 AM
Carpet only gets wet when it rains right?
if Yes- You have the dreaded "fallen down rubber seal problem" under air inlet cowl- passenger side- do a search for wet carpet- grand prix- and you will see all the fixes and photos etc-- basically just glue the water deflector back into place--
If no- then pull the rubber elbow off the condensate drain - mid center on engine side of firewall and clip the nipple off- W-cars are only GMs to use the nipple- so cut it off- and see if drain works better
