#5 cylinder not getting any fuel
laxman21
05-29-2009, 04:13 PM
What are the possible culprits and solutions
99 blazer 4.3 w
MT-2500
05-29-2009, 05:02 PM
Could be many culprits.
Need to find the problem to get a solution.
Is fuel pressure 60/66 lbs?
Are all injectors getting good injector pulse?
Is the injector plugin seated down good?
How are you checking for no fuel to the 5 cylinders?
Is the other cylinder flooding?
Are spark plugs wet on the end with fuel or dry?
Did this happen all at same time?
laxman21
05-29-2009, 05:06 PM
Are all injectors getting good injector pulse? How do you test for
Is the injector plugin seated down good? is it a single one or 6 individual ones?
How are you checking for no fuel to the 5 cylinders? They said the took the plug out, compression check it and tried a different plug
Are spark plugs wet on the end with fuel or dry? dry
The mechanics that are putting in my long block called and told me that the #5 cylinder was dry and they want to charge like 800 to replace the spider unit.
blazee
05-29-2009, 05:16 PM
The mechanics that are putting in my long block called and told me that the #5 cylinder was dry and they want to charge like 800 to replace the spider unit.Something like that would make me look for another shop. Those guys are either stupid, or crooks. Setting aside whether or not there really is a problem with number 5..... the injectors can be replaced separately, a replacement injector is less than $50, and shouldn't take more than an hour to replace. Also, considering that everything should already be apart to switch it to the long block, it would only take 5 minutes. Alternately, you can buy the complete updated MFI injection assembly that eliminates the common problems of your current system for less than $200.
Keep in mind that I'm not telling to buy or replace anything, until you find out the problem..... just telling you that their pricing is WAY off.
MT-2500
05-29-2009, 05:18 PM
They do not know what they are doing or they are trying to rip you on that deal.
99 does not have a spider assembley injecor system.
Each injector is seperate and can be replaced one at a time if bad.
Proper testing before throwung parts at it.
Tell the to check fuel pressure and for lose of injector pluse to that cylinder.
Post back your fuel pressure readings.
And if it is losing injector pulse on that cylinder.
And how they are testing it?
laxman21
05-29-2009, 05:31 PM
Really? Trying to rip me off? Told me it was one unit and about $400 for the part.
I am picking it up as it is on Monday.
MT-2500
05-29-2009, 05:41 PM
On the injector go to your local parts place and price one injector and gasket set for it.
We do not have all the details but they could be ripping yoe off just not know what they are doing.
laxman21
05-29-2009, 05:59 PM
I will update on Monday when I pick it up and get an estimate
Anyone have a picture of the 99 fuel injector system? Or the updated kit?
laxman21
05-30-2009, 08:18 AM
They called and said they tried to clean out the spider and couldn't and now I shouldn't drive it in this condition.
MT-2500
05-30-2009, 08:37 AM
Right on do not drive very far.
Find a good repair shop and get it checked and tested.
Let us know how it goes and good luck
laxman21
05-30-2009, 11:24 AM
What will driving it do?
I'm gonna trailer it home.
MT-2500
05-30-2009, 12:54 PM
If drove very far you may be putting in another engine.
You can only drive a few miles with engine damage starting up.
laxman21
05-31-2009, 06:38 PM
I'm confused now? Could it be a clogged poppet valve they are trying to clean?
Is the the injector part they could just replace?
http://www.autopartswarehouse.com/images/product_images/images/WORLDPAC/W01331614662DEL.JPG
MT-2500
06-01-2009, 07:40 AM
If the injector is not working and it is getting 12 volts and injector pulse to it they can and should be replaced.
Around 200$ parts and labor.
They do make cleaner stuff for the puppet valve.
Sometime helps on one that is just dirty.
But if it is bad replace it and be done with it.
Good Luck
laxman21
06-01-2009, 07:44 AM
OK. So there are defiantly 6 injectors in the system?
laxman21
06-01-2009, 07:45 AM
If it's not getting a pulse what does that mean?
MT-2500
06-01-2009, 08:37 AM
Yes 6 injectors and they can be replace one at a time.
If no injector plulse to the injector it will not work or squirt fuel.
If injector not working the first thing to check for is 12 volts to it and injector pulse to it.
A injector noid light tester works good for checking injector pulse.
Good Luck
pnellany
06-01-2009, 09:38 AM
Fuel acts as the upper cylinder lubricant no lubrication means engine failure
I have seen pistons fused to the cylinder bores due to bad injectors in as little as 5 miles.
You can definitely replace a single injector or swap out one to see if it is clogged.
Since only one is failing you have enough fuel pressure.
This is a minor fix and would cost 90 bucks at my shop
MT-2500
06-01-2009, 11:13 AM
Injector is 65.00$ cost plus gaskets.
Does not leave much labor at 90.00$ FOR THE REPAIR.
laxman21
06-01-2009, 11:48 AM
So what do you charge for an injector or replacing the whole unit?
MT-2500
06-01-2009, 12:06 PM
I never price a job over the net or phone and I always check it out first to be sure what the problem is.
But as said on one injector the cost is 65.00$ = parts markup plus gaskets and shop flat rate labor + a hr diagnostic time.
blazee
06-01-2009, 01:22 PM
$65 is about the most I'd let them charge me for the parts. They can get them for considerably less than that. That would be considering that top quality parts were used. The actual original equipment Delphi brand injector can be had for around $50. Budget injectors can be bought for the mid $30s (I still recommend OE though). I never let a shop charge me more for a part than I can get it myself. Even doing so they can still make a profit on markup.
The job can be done in an hour, but that is pushing it a little to ask them to work on something for an hour straight. Generally for every 15 minutes of work there is a 5 minute break. GM Labor rate for this job is 1.3 hours. For an average shop that doesn't do them regularly, or may not have done one before, I would allow them 1.5 - 2 hours just to make sure they're not too rushed.
pnellany
06-01-2009, 01:55 PM
my cost for an OE injector is 23 dollars plus change time to replace it in the book is 2 hrs my guys do it in about 30 mins.
90 bucks is fair for me and fair for my customers
I could charge more but then I wouldnt have over 90% repeat business with more recommendations daily.
Its all about the future and not right what I can make for the moment.
laxman21
06-01-2009, 03:01 PM
Looks like it was leaking fuel from the regulator too.
MT-2500
06-01-2009, 04:25 PM
Are you sure that is not the real problem?
Instead of bad injector?
MT-2500
06-02-2009, 10:32 AM
Fellows give me a break on the price war.:sarcasm1::lol2:
Are you all sure you all are pricing out right a 99 4.3 V6 code W fuel injector?
A Gm dealer OEM injector for a 99 4.3 V6 code W engine is 142.00$ list and my cost with a good discount is 99.95$
A aftermarket BW fuel injector for it is about 65.00$ Cost
blazee
06-02-2009, 03:08 PM
A aftermarket BW fuel injector for it is about 65.00$ Costhttp://www.rockauto.com/catalog/racatalog.php?carcode=1353619&parttype=6224
Cheap part $36.99
Delphi Actual OE $56.79
AC Delco $85.79
Part from GM MSRP $142.22
Part from GmPartsDirect.com $73.95
The guy I deal with has been a tech in this area for 25 years, and can get me parts from the local GM dealer for about 20-25% less than the GMPartsDirect Price.
MT-2500
06-02-2009, 03:25 PM
Cheap part $36.99
AC Delco $85
Thanks Blazee
That sounds good.
Always pays to know someone or someone that knows someone.
Now we need to hear from laxman21
laxman21 how is it going with it?
laxman21
06-02-2009, 06:04 PM
All fixed. Runs good. Updated injection system installed.
blazee
06-02-2009, 06:31 PM
All fixed. Runs good. Updated injection system installed.:thumbsup: The MFI units are a great upgrade, and will give you years of trouble free service. Did you do it yourself or have them do it. If they did it, I hope they didn't charge you more than about $400
laxman21
06-02-2009, 06:59 PM
I had them do it because I decided I wanted the truck running and didn't want to F up a new engine. The part was about that.
