2000 Explorer,windows Won't Work
warwolf
05-24-2009, 06:02 PM
No power to door switch,fuses are Ok,No broken wires at door boot..Windows Are the only thing not working..Any Idea's??????????
shorod
05-24-2009, 09:38 PM
If your fuse is good and there isn't power to the door switch but other accessories work (sunroof, radio, etc.), you have to have a broken wire or loose connection somewhere. Are you sure there isn't a broken wire in the door boot? The wire conductor can break inside the insulation.
Have you verified 10-amp fuse 26 in the Central Junction Box as well as 30-amp fuse 4 in the Battery Junction Box? Fuse 4 powers the Accessory Delay Relay and fuse 26 powers the Battery Saver Relay.
-Rod
warwolf
05-27-2009, 06:04 PM
I.ll Check the wires with a test light this weekend. I was just pulling on them to see if one was broke. Thanks for the reply.
