P0440
expjoe
05-13-2009, 09:14 AM
As you know I recently changed out my fuel pump 2 days ago and now my SES light is on, I had the code read and it is P0440. What is my first move here guys??
jakegday
05-13-2009, 10:41 AM
first move, make sure your gas cap is good, then make sure its on tight
expjoe
05-13-2009, 11:37 AM
How do I know it is good? Should I clear the code?
jakegday
05-13-2009, 12:30 PM
just look at it. if you think something doesnt look right on it, then get a new one.
if i were you, i would just make sure its tight, clear the code, and wait and see if it comes back
doctorhrdware
05-13-2009, 01:56 PM
It also could be a problem with the fuel pump assemble o-ring. Since he has replace the fuel pump it is possible that the o-ring did not seal properly.
expjoe
05-13-2009, 02:05 PM
How would I know if the o-ring didn't seal properly??Would I have to pull the pump again?? The car runs fine and does nothesitate at all, maybe I will just replace the cap at this point!?!
richtazz
05-13-2009, 02:18 PM
The fuel tank vent valve is located right next to the fuel pump module. I would take the access cover back off and make sure you didn't accidentally disconnect the wiring harness or the purge hose from the vent valve while changing out the pump.
HotZ28
05-13-2009, 02:23 PM
How would I know if the o-ring didn't seal properly??If the O-ring does not seal, you will get a P0440 DTC. :sly: Check the simple things first, but anytime the pump is replaced, a new O-ring should be installed. Very common mistake that will come back to haunt you! :banghead:
expjoe
05-13-2009, 02:38 PM
I just double checked the wire harness, everything looks fine, I also looked for the purge hose ; I am not sure which one that is?? Could you give me some direction?BTW the pump assembly came with a new o-ring and it was used(and greased); the pump went in good and tight.
Firstymer
05-19-2009, 10:53 PM
My 00' GP SE with 125,000+km 3.1L V6 had pull up that exact same code P0440. Where is the air solenoid? Any pic or diagram to fix the problem?
Firstymer
05-19-2009, 11:01 PM
Where exactly is the fuel tank vent valve? Any pics or diagram to check for replacement?
expjoe
05-24-2009, 09:14 PM
i just filled up and left a good amount of fuel on the ground ..... this would tell me the o-ring did not seal properly. I will be removing and replacing the o-ring and snap ring, maybe it got twisted when i installed it??. thanks for all the help!
