problem with keyless and lights
chrissbee77
04-09-2009, 03:01 AM
I have a 2001 grand prix gt 3.8 n/s. If you look at my last post im sure you will see what ive been dealing with. I have everything up and running no more ticking noises and everything works. Only problem is that after changing my DRL module (swap from yard) the daytime lights work but when i walk up to unlock my car using the remote the outside lights no longer flash. It still unlocks and the interior lights come one but the outside lights no longer flash. It used to and i did not adjust any settings. Any ideas. Thanks
BNaylor
04-09-2009, 06:44 AM
Have you tried reprogramming? If you have the owner's manual refer to Chapter 2. It sounds like the the remote lock/unlock confirmation was disabled and it is now in Mode 1. Default should be Mode 4. Before the troubles was it programmed to have the horn sound briefly in addition to the headlights?
