Programming Remotes 2006 Solara-Works good
upssnowman
04-08-2009, 07:19 PM
To program your remotes (FOBS) this works on the 2006.
1. Start with the following conditions: your in the driver's seat:
a. Key is out of the ignition
b. Drivers door is open (all other doors closed)
c. Drivers door is unlocked (other doors don't matter)
2. Insert and remove the key from the ignition twice within 5 seconds.
3. Close and open the drivers door twice within 40 seconds.
4. Insert the key into the ignition and remove it.
5. Close and open the drivers door within 40 seconds.
6. Insert the key into the ignition.
7. Close the door.
8. Turn the key in the ignition on then off.
9. Remove the key from the ignition.
10. The power lock should automotically cycle once to indicate that you have successfully entered the program mode.
11. With 40 seconds of entering the program mode,
a. Press both the transmitter lock and unlock buttons simultaneously for
a duration of 1 to 1.5 seconds.
b. Within 3 seconds, press the transmitter lock button for more than one
second and release.
c. If the transmitter has been succesfully programmed, the power locks will automatically cycle once. If they cycle twice the remote has not been accepted.
d. If multiple remotes are to be programmed, repeat steps a-c.
12. Open the drivers door.
