help! i am having a problem with my 94 roadmaster driverside turn signal
reaperjay
03-31-2009, 09:21 PM
i have this 94 roadmast. all the turn signals worked fine aweek ago. now all of a sudden the driverside turn signal wont work. i have changed the bulb in the front and back end. the front wont light up. the turn signal indicator light stays on even if the turn signal is turned off. it doesnt make that clicking sound for that turn signal too. i need help a.s.a.p
'97ventureowner
03-31-2009, 09:32 PM
Welcome to AF !
Have you checked the turn signal flasher ? It's a fairly inexpensive part and would be the next logical step to look.
reaperjay
03-31-2009, 09:37 PM
i havent tried that yet. thanks. i was hopeing it was something i might be able to fix
'97ventureowner
03-31-2009, 09:50 PM
If that is the problem then it's a fairly straightforward fix of simply changing out the bad one for a good one.
reaperjay
03-31-2009, 09:55 PM
it is going to be fun trying cause my mom needs the car to drive 3 hour to a doctor tomorrow. thats why i was trying to see if there was a way i could fix it tonight.
