96 braada throttle body
jhymel
03-30-2009, 04:23 PM
i have a 96 bravada and went browsing around for info about fuel econ and power increases. i started with k&n air filter, then about a week later i did the "swiss cheese" air box mod and finally about a week after the air box i read about a mod that involved taking off the restrictor plate on the bottom of the throttle body butterfly valve off.
after the throttle body mod i noticed a wonderful increase of power but the engine wants to run fast, by that i mean if i start off at stop and dont accel it will get to about 25mph and shift into second with out me pressing the accel pedal. i did plug the holes in the butterfly valve with a rivit that i put in the place of the stock rivits that held the plate on.
now for my question, has anyone ever done this modification and if so what was the result.
Chris Stewart
03-31-2009, 05:03 PM
I haven't done that mod but you might look for unplugged vacuum lines and the possibility of the butterfy shaft & TPS not being in the stock position
or,
the restrictor plate being part of the throttle and it's removal leaving a gap or opening that allows more air in.
ericn1300
04-01-2009, 06:34 PM
You shouldn't remove the restrictor plate, just modify it which takes some precision, or easier yet get a mod kit for it here www.cfm-tech.com
your idle might reduce as the ECM resets the IAC valve over time, but don't count on it.
