Bad Smell At Higher Speeds
TheDeal526
03-22-2009, 06:42 PM
2001 Ford Escort ZX2 2.0L L4 97,600 miles
I recently had to do some work related traveling for 2 months, and my Escort remained home and unused the entire time. I noticed the other day when I get up to highway speeds, my car produces a funky smell. It's kind of hard to describe the smell. I would say, it smells like I'm driving inside a chemical plant. Anyone have any ideas?
Thanks!!!
rhandwor
03-22-2009, 08:23 PM
A leaking heater core will cause odor. With the defroster running watch the window for discoloration.
Watch on top of the motor for a cracked thermostat housing.
chrisanthony
03-23-2009, 08:12 AM
Does it smell like burnt oil?..if it is you might have to change the manifold gasket. I used to get oil leaks from there, then it used to smell really awful.
AzTumbleweed
03-23-2009, 09:16 AM
Narrow it down- Put your heater control on recirculate. If you still smell it then it's coming from inside the car. If you don't smell it then it's coming from outside. I've always thought antifreeze smelled like pancake syrup. On my car it sometimes leaks a little oil onto the exhaust pipe and it smells up the inside of my car. Putting my heater/AC control on recirculate stops the smell from coming in.
chrisanthony
03-23-2009, 09:35 AM
Your escort has reciruclate?..mine doesnt..
denisond3
03-23-2009, 03:13 PM
On early 2nd gen. Escorts there was a lever just for 'recirculating vs outside' air. On the later ones, (like 94 for instance) 'recirculate' was the leftmost position of the heater outlet selector lever.
AzTumbleweed
03-24-2009, 09:10 AM
And on many cars the "MAX AC" position is recirculate.
TheDeal526
03-24-2009, 06:23 PM
There is no discoloration on the windshield. I always run the climate control on the defrost/feet setting, and I never noticed any discoloration. I did have it completely tuned up with a coolant flush, oil change, and ran some lucas in the tank. I haven't noticed the smell since. I hope its fine now. By the way, my first thought was a bad catalytic converter. Would that make any sense at all?
AzTumbleweed
03-25-2009, 08:28 AM
A bad cat would smell bad but if you're smelling it inside the car then you also have a major exhaust leak.
EscortDave
03-26-2009, 06:26 PM
Check the serpintine belt. When my tensioner began to freeze up the belt began to burn up as the pully was no longer spinning so the belt just ran up against it. It smelled bad and smoked.
MyEscort99
03-30-2009, 08:06 PM
Please be gentle. This is my second post only. I had noticed similar problem with my ESCORT 99 couple of years ago. There are traces of a plastic sheet stuck and burnt underneath my Escort.
