rear brakes 2001 express 2500
rangerone766
03-17-2009, 10:57 AM
do i need to pull the axles to change the rear brake pads on a 2001 express 2500?
on my old 1996 g30, the shop charged us an arm and a leg to do a brake job on the rears because they said the axles had to come out because the drums and axles were 1 piece.
on the fronts do i need any special tools to get the calipers off? my old '96 had an odd set up, but i was able to get er done.
MT-2500
03-18-2009, 08:37 AM
Got dual wheels?
Got dual wheels?
rangerone766
03-18-2009, 09:41 PM
its only a standard van, not a dually, the old g30 was not a dually either.
MT-2500
03-19-2009, 09:20 AM
Pull hub cap and wheel off.
Does the axle have any bolts holding it in?
If so then have a look and see if drum will come off of hub without removing axle and hub.
Good Luck
Good Luck
