99 olds lss
99lss
03-16-2009, 01:54 PM
i recently purchased a 99 olds lss with 122000 miles on it. i replaced the front struts plugs wires oil and air filter. the car runs great most of the time but there are times where it doesnt seem like it is running on all 6 cyl. it only does it every now and again and it does it so little that i cant determine why or what is causing this. i have no lights on on my dash. can someone please advise me!! thanks
prunsk
03-16-2009, 03:13 PM
Try a new tune-up with new spark plugs.
99lss
03-16-2009, 03:19 PM
i changed the plugs and wires with a/c delco parts 7 dollars a plug!
prunsk
03-18-2009, 12:10 AM
The first thing that should be checked is the powertrain on board diagnostic(OBD) system check.Having the proper OBD Scan or diagnostis tool would come in handy for some of these checks.It would give you a lot of codes to help diagnose what your lack of power could be caused from.
Check the air filter
Check for low fuel pressure
Check for contaminated fuel
Check for proper ignition coil output with a spark tester
Check ignition coil for cracks or carbon tracking
Check PCM grounds for being clean,tight and in proper location
Check exhaust system for obstructions
Check catalytic convertor by checking exhaust system back pressure
Check torque convertor for proper operation
Check boost control system(A scan tool range 0%-100%) represents the amount of manifold boost pressure commanded by the PCM.100% indicates full boost commanded
Lots to check Good luck
99lss
03-18-2009, 02:49 AM
out of those recommendations, what can i have checked at say auto zone?
