95 Cadillac Northstar Engine/Trans - NY
GSXMEN
03-15-2009, 06:53 PM
If anyone is looking for a Northstar engine swap into a Fiero, kit car, etc - or just a stock replacement, I have a good running Northstar engine & 4T80e trans from a '95 Deville for sale. This is a Vin Y (LD8)engine .... 275hp.
Car only had 80k miles.
Starter was acting up, so would need changing. Could be just a bad connection at the starter....I'm told that's common as well. Either fix it yourself, or I can replace starter & intake gaskets for cost of parts & modest labor charge.
Engine comes with engine wiring harness.....from ECM connectors to the fuse area.
Also comes with front accessories......alternator, AC comp., etc.
*Will also work in other 93-95 Caddies. If you have a bad Vin 9 engine, you could just change your cams over to this one.
Price lowered to $800/best offer.....$700 minus tranny.
Other pics here: http://s35.photobucket.com/albums/d191/GSXMEN/Northstar%20Engine%20and%204T80e
http://i35.photobucket.com/albums/d191/GSXMEN/Northstar%20Engine%20and%204T80e/Northstar005.jpg
Autotropolis12
03-16-2009, 02:52 AM
can you give the more information about this........?
williz57
04-12-2010, 09:16 PM
Do Items get deleted here when sold? There are some old posts here it would be a common courtesy to remove when sold.
GSXMEN
04-12-2010, 09:35 PM
The engine above is still available, if that's your question. Price is even lowered to $600.
When sold I intend to delete the ad.
BTW....thanks for bringing a 13 month old thread back to life. I'm sure the moderators are going to have a field day with this.
