Lifter Noisy 3.4
richamer1
03-13-2009, 07:42 AM
I have a 00 Montana 3.4 on cold mornings I have a lifter ticking for several minutes when I start it. I am getting ready to do a intake gasket job on it. Would it be fairly easy to replace it at that time? Also how can I detect which one it is? My daughter had a 95 Olds 3.1 that did the same thing I used 5W-20 oil and it helped that car had roller lifters that were very expensive does the 3.4 also have rollers ? Is this something that I need to worry about or just let it warm up and go on ? It has 132K on it Thank You
1999montana
03-17-2009, 10:41 AM
Don't know if it has rollers. Are you certain it is a lifter? These engines have a tendency for piston slap due to the short skirt on the piston. The sound usually goes away as the engine warms up and the piston expands in the bore. Lifters can tick too, but often the plunger inside the lifter is stuck and the lifter will continue to tick even after warm up. If it goes away on warm up, don't worry about it.
mhall02
03-17-2009, 10:53 AM
I would second the lifter like noise you hear on startup when cold, mine has always done it, and it now has over 185,000 miles, no new lifters. The noise goes away when warmed up. Bad lifters will peck an knock and rattle at all times as mentioned above, not just at first.
fritcr
03-27-2009, 09:47 AM
My 01 does it and so does my moms 04. I guess piston slap? My 01 is worse but then stops pretty quick after starting it.
wafrederick
03-27-2009, 07:05 PM
The 3.4 including the 3100s are known for eating camshafts also.The 3.4 has rollers
birar
06-23-2009, 01:41 AM
leave it be ive had 4 3100s and they all were noisey in the morning when cold most of them had over 200,000 to just the nature of that engine
