power window switch center removal 2001 gp
aliasmax
02-28-2009, 08:26 PM
Hi all, how do i remove the power window switch center from the drivers side door. my wife left the window open one night and it rained on the switches. now the drivers window won't go up unless you play with the button a lot. do you have to remove the whole door panel or can you just pop out the switch assembly? thanks all
BNaylor
03-01-2009, 09:04 AM
You do not need to remove the door panel.
Carefully using a small flat blade screwdriver, insert at the lower end of the switch trim piece (bezel). Push in to release the retaining tab and at the same time lift up on the lower part of the trim piece.
aliasmax
03-01-2009, 10:10 AM
I thank you for the information and the reply. from all the time i have been on this site and reading through the threads, is there anything you don't know BNaylor? damn your good. thanks again.
