Transmission Question.
01bluerodeo
02-17-2009, 04:39 PM
Hey all. I have a leak coming from under the transmission. I had a new gasket and filter put on,but this is not where the leak is coming from. It looks as if it is coming from another area. The area above the smaller transmission pan. I got some part names off of myisuzuparts.com. Here they are because I believe that this is where the leak is.
Ring;snap,adapter
Cover;piston
Plus four other parts that go inside.
Now my question,or questions.
Are these hard to change? And are the expensive?
It doesn't leak much when sitting still. But when I go to drive it.....it goes everywhere. Thank you for any info.
Tony
FL 3.2L
02-17-2009, 06:57 PM
Search "accumulator piston cover." It is an $11 part, I think. Get a new snap ring, too. It can be easy, but it can give you a rough time coming out. Search will give you some good tips.
FL 3.2L
02-17-2009, 07:02 PM
http://www.automotiveforums.com/vbulletin/showthread.php?t=184133&highlight=leak
01bluerodeo
02-18-2009, 10:59 AM
Thank you.
Tony
01bluerodeo
02-18-2009, 11:14 AM
Thanks. Also. I done a search on the part numbers. A link lead me to hondapartsnow.com .I understand that the rodeo and passport are basically the same. Will these work? My rodeo is a 2001. It said the parts are for a 98 - 02 passport. The ring is $2.66. And the cover is $7.50. Thanks again.
Tony
FL 3.2L
02-18-2009, 05:12 PM
Yup.
You're welcome!
