s10 4.3 w
johndeere601953
02-15-2009, 07:46 PM
what would cause purpel spark ON THE in side coil fields? The coil wire from the distrb to coil lights up with purple spark on the out side, has new delco wires, tried 2 new flat top TYPE distrb caps and a new rotor, tried a few coil'S, tried few coil wires to, THe COIL WIRE has SMALL DEEP PURPLE ARC all the way up and down it, It CaUSE's THE TRUCK TO MIsfire, AND HIGHER RPM THE MORE SPARK IS SEEN , has new delco spark plugs to.
j cAT
02-16-2009, 02:31 PM
what vehicle year is this ?
johndeere601953
02-17-2009, 12:39 AM
1995 4.3 w singal type fule injection with popets spider type i think, coil wire cause the miss
j cAT
02-17-2009, 10:45 AM
check the plug/coil wire resistance..if open this will cause to voltage to jump .....make sure that the surfaces of coil/cap/rotor are clean and there is no carbon tracking...make sure the coil wires are clean and secure...
johndeere601953
02-17-2009, 07:16 PM
OK OWNER BEFOR ME had a misfire isssue before he sold it, he had new spiders put in it, and he put a 1998 fule pump and gas tank in it, he got the miss out, but it has come back, it had new bosh 8mm wires on and napa coil, when i got it with a misfire, what i have put on it is two new distrb caps, new rotor, gm ac delco plugs and gm delco wires iv tryed 3 used working ICM'S , tryed 4 other used coils and 1 new coil, miss left, then come back, its haD A gm service injector flush and clean with no bleed off of the injectors at all, truck has 200k easy life miles the 98 fule pump only has 6 more psi than stock, WORKING ON IT THIS WEEK END so find out more, its a 95 truck
2percent
02-17-2009, 09:55 PM
Mine misfired due to the spider ass loading up in the upper intake. these are known to cause problems I would suggest looking for washing and go from there.
