AIR DRIED BEEF DOG FOOD
1999 Ranger -Steering not retuning to center
MORROW5
02-11-2009, 06:52 PM
I got a 99 ranger shortbed had upper and lower ball joints installed, then had front end alignment done now it won't return to center. They want me to return to them so they can check it out more and say it is proubly the steering box? It all worked fine till I went and put ball joints in it. I think the camber or caster is still off ! Any body got any advise? :rofl: Thanks!
mrmikey
02-12-2009, 05:59 AM
Was the stering wheel straight ahead when the joints were installed? Some joints and it may or may not be the case with yours, are mounted so there is no actual 'turning' in the joint. It's rubber bonded to each piece that flexes as the wheel is turned, if it's installed when the wheel is off center, it'll be biased one way....Mike
MORROW5
02-12-2009, 07:58 AM
Every thing lines up ok wheel just needs help to return to center.
Everything is tight and working well but when you go to turn you have to help the steering wheel back to center.
Tracks fine going down the road. Took back to them today and will find out what they say this time. I will post what they say as soon as I know somthing esle.
Thanks for the reply !
MORROW5
02-17-2009, 09:50 AM
Well got it back for the second time and they still say it is the steeringbox. I still have a hard time believing it cause it drives fine and returns almost all the way to center but lacks about 4 inches of turning the wheel to get it back to center in both directions. I think I am going to try a new place of service cause I have no way of checking theses things out for myself. Any suggestions ? Thanks in advance!:rolleyes:
Davescort97
02-17-2009, 11:34 AM
It could be the steering box. If the adjustment nut and shaft is too tight it will prevent the wheel from returning back to center. I am not sure about your particular model. It may not have an adjustment on the box. I do know that if there is too much + caster on the front wheels it could prevent them from returning to center. Trust the people doing the alignment. They are thinking along the right track.
transgta
02-18-2009, 04:24 PM
Hey morrow hope u dont mind me askin but my son has a 99. Took to get allignment they said it needs ball joints and wanted 850 buks i was floored. Is that reallity?
Davescort97
02-18-2009, 11:50 PM
If the ball joints that were put in weren't greased that would cause them to bind up and not allow the steering to return to center. Same thing with tie rod ends.
MORROW5
02-19-2009, 02:01 PM
yes well it was about $600.00 here in va.
MORROW5
02-19-2009, 02:03 PM
I will check and put more grease in them just to see if that helps ! thanks!
