Where can i get...
Honda_Racer
03-25-2003, 06:11 AM
the manuals on the net to change my DPFI intake with my MPFI intake thx guys and is it really hard since i know shit if i read manual will i be able to...?
1990civic
03-25-2003, 06:18 AM
dude heres the truth. the way most of us on here have learned about honda engines is by trying, messing up, and trying again. i personally dont know which wire is which on the engine harness, so i would get a whole new harness out of a (SI) from steering wheel to battery. but thats because i dont know which wire is which. everything else is quite easy. with the hondas its either color coded, or it will only fit in one place. what i would do is contact AMI and see if she can recommend some good instructions. because you cant just assume that any directions to do this swap on the net are correct.
crxlvr
check here
www.4thgenerationcivic.com
tanas
03-25-2003, 08:25 AM
the march or april HonaTuner mag has the wiring info for a dpfi to a mpfi. As for the rest of the stuff needed, I know just about as much as you do probably.
