Heat staining exhausts!
Guiddy
10-22-2001, 01:21 PM
Something all you guys need to get into! Looks great!
http://www.tamiya.com/english/howto/bike1/tip1.htm
JE123
10-22-2001, 02:25 PM
That is a great tip. How much does an airbrush cost like that one? It doesn't have to be a tamiya one.
Guiddy
10-22-2001, 04:05 PM
If you want a topload like that one, they go for around £100 here.
I have one and love it to bits.
Really easy to clean as you harldy put any paint in it!
JE123
10-22-2001, 04:14 PM
What is a good cheap one that has an adjustable nozzle. One that can spray wide and narrow for detailing.
Guiddy
10-22-2001, 04:36 PM
the trouble with most is the fact they are suction fed, which deteriorates quickly when the seals harden, plus you need a lot of paint because the gun has to suck it up!
You can get a nice Badger one for £50 though.
http://www.badger-airbrush.com/images/150.jpg
MercCougarXR7
10-22-2001, 06:22 PM
Go with a Badger 350 - easiest model for beginers. It has a bottle feed (from the bottom), it's easy to assemble/dissassemble, and doesn't cost too much in the first place.
As for the exhaust tip - I don't like it. Looks Very cheesy - I like my models to look like they had just rolled off the Factory floor :).
Jay!
10-22-2001, 06:39 PM
Originally posted by MercCougarXR7
As for the exhaust tip - I don't like it. Looks Very cheesy - I like my models to look like they had just rolled off the Factory floor :). I concur. Though it's a good detail bit for a race car. :D
Guiddy
10-23-2001, 03:45 AM
I'll show you mine and let you make your own minds up!
primera man
10-23-2001, 06:24 AM
They make it look so easy. !!!
Nice tips on how to do it.
Moppie
10-23-2001, 07:06 AM
The problem with weathering, and I think this is the answer to a debate which is older than any one here is: Once you've whethered on part, you can't stop. Next you have to add tyre wear, scoring on the brake discs, bugs, oil stains, dirt, worn seats, etc etc.
If your going to add realism to a car, to make it look a little used, then you need to make all of it used.
But if your going for straight off the show room floor look, then you don't want to add wear any where.
If your going to Weather parts, you have to weather the whole car to keep it all in balance.
MercCougarXR7
10-23-2001, 06:09 PM
Yah - what he said ;)!
What color is that on the underside of your car Guiddy? I like it - looks like a combo between Gun Metal and Steel :).
Guiddy
10-24-2001, 02:29 AM
It's Honda Silverstone Metallic, the correct S2000 colour!
Jay!
10-24-2001, 12:56 PM
What color is that on the underside of your car Guiddy? I like it - looks like a combo between Gun Metal and Steel :). It's Honda Silverstone Metallic, the correct S2000 colour!LOL! You're not far off, Merc. To make Silverstone Metallic, you mix one part gun metal to two parts chrome silver. ;)
MercCougarXR7
10-26-2001, 10:24 AM
Thanks Jay! I've only just started to mix and match paints - I have so many old paints just laying around, I may as well put two together to make a new color (notice the 3 2's :D?).
I made a beautiful color from Olive drab green by adding some metalic dark blue. It now is the perfect color to put on the Japanese Army version of the Zero.
I'm definately going to make that Silverstone paint - great name for it too :)!
Jay!
10-26-2001, 11:51 AM
Here are the seven factory colors the S2000 is offered in. Silverstone Metallic is the first one. :)
http://members.aol.com/silverstones2000/s2kstripe.jpg
