please help 96 firebird will start but dies
lonnie3232
02-02-2009, 07:57 PM
3.8 v6 ok this is driving me nuts lol i park it about 2 or 3 month runing good went to start it and it wood start run about 5 sec and die got good fuel pres had the module tested all good is there a switch or sensor that runs the injector its not in the firing just like the gas leaves it i baypass the VET and still the same thing cant it be the BCM please help thanks :confused: :confused: :confused:
lonnie3232
02-03-2009, 08:22 AM
please some one help anything at all
Genopsyde
02-03-2009, 10:45 AM
when it runs for the said 5 seconds, does the fuel pressure hold or drop?
lonnie3232
02-03-2009, 11:09 AM
it holds good
lonnie3232
02-03-2009, 11:10 AM
just went a got a new cam sensor maybe that will help (will that dint help at all ) will the oil presser switch make the inj not firer
lonnie3232
02-04-2009, 04:27 PM
any one out there help please
wrightz28
02-04-2009, 04:54 PM
What exactly is the pressure at and staying at after it dies? It sounds as if it is only running on the primed pressure. Additionally how much gas was in it when parked and what kind of conditions has the vehicle been subjected to while being stored?
lonnie3232
02-06-2009, 01:27 PM
What exactly is the pressure at and staying at after it dies? It sounds as if it is only running on the primed pressure. Additionally how much gas was in it when parked and what kind of conditions has the vehicle been subjected to while being stored? whin i first trun the key on it about 50 psi whin it starts it drops to about 40 psi dry conditions about 1/4 tanck of gas but i put more gas now it about 3/4 tank just order a new fuel pump hope it works tanks for the help what do you think
muff34
02-06-2009, 11:23 PM
How is it with 3/4 tank of fuel in it? The reason I ask is because my`95 is suckin` air at 1/4 tank of fuel. Apparently an issue with this era faulty/inaccurate sending unit. I`m likely wrong just thought I`d throw this out there you never know, maybe it`s picking up a whif of fuel!
lonnie3232
02-07-2009, 08:06 AM
How is it with 3/4 tank of fuel in it? The reason I ask is because my`95 is suckin` air at 1/4 tank of fuel. Apparently an issue with this era faulty/inaccurate sending unit. I`m likely wrong just thought I`d throw this out there you never know, maybe it`s picking up a whif of fuel!i was thing the same thing but i was wrong it still boing the same thing parts store sead the fuel pump psi wood be no less then 55 psi to 60 to run this one is 40 psi to 50 psi cant get it over 50 at all any thing u can think of but the fuel pump is bad what do u think fuel psi reg mybe thanks :confused: :confused:
lonnie3232
02-18-2009, 06:42 PM
well got the new fuel pump in still the same thing but i checked the injectors with a noid light the light works when u turn the key on and when it first starts then the light stops blinking then the car dies now what please help thanks
wrightz28
02-19-2009, 10:28 AM
I'd start checking the wriing out then and make sure no little critters chewed on them while sitting, especially the cam and crank sensors.
lonnie3232
02-20-2009, 10:14 AM
geting ready to do that next well let u know how it gos thanks dos it hurt if u leave the battery out for about 2 or 3 weeks
lonnie3232
02-21-2009, 08:01 PM
well got it run today u are right it was a wire into dam mouse lol i thank all of u for your help thank u all so much ill help here as much as i can here if that all right with you all and thanks agen:biggrin::biggrin::biggrin::biggrin::biggrin:: biggrin:
wrightz28
02-21-2009, 10:40 PM
Nice, good to help, I've been on a draught since bing divorced, glad to help. So they chewed up the cam wiring?
lonnie3232
02-22-2009, 01:37 PM
i think so it was behind the ecm a little blue wire now its got to relearn every thing hate to here about the divorce man wemen can tair a man all up
